So, i tried to transfer 325 videos at once to my usb and that took about a day. But once it was done i realised that the videos got corrupted trough it. I recieve the error code 0xc00d36c4 when trying to start the video. I tried a lot so far like using the paid version of wondershare, without any avail tho. I was only able to fix like 5 videos in total but the rest just didnt seem to work. I think it got corrupted since my wifi restarted sometimes during that transfer. I am kinda lost i can't rly think of an way to fix it so thats why i am making a post here.
Results 1 to 9 of 9
If you don't have the original files you transferred then there's usually no way you can recover the files,next time you transfer them keep the originals.
I think I would be suspicious of 325 videos fitting on a USB stick at all. What size are they and what is the stick capacity?
Brian. -
256 gb and up will fit them.
Well the USB stick is 976 gb big and the videos all together around 700gb, most of them are just from 2020 where i played on some Minecraft servers with friends and i would like to rewatch them. I don't think that i have the original files any longer since i transferred all of them over to my USB stick at once xd But isnt there a way to maybe fix them? Since i was able to recover like 5 of them
I would recommend that you first verify that your 1TB USB pendrive is genuine and fully functional.
Use a tool like H2testw or FakeFlashTest but make sure you get them from reputable websites. -
I tried it but all of my files turned to .mkv file when i transferred them and if i try to convert them to .mp4 files they loose all of their gb and turn into 1kb videos
When you transfer files to your usb you dont lose the original ones,are you deleting them after the transfer?
Panasonic TV not displaying subtitles from USB stick
By millsy5 in forum SubtitleReplies: 34Last Post: 13th Feb 2021, 16:34 -
How to play the recording of a Sony Bravia TV on a usb stick?
By cypherinfo in forum Video ConversionReplies: 12Last Post: 11th Jan 2021, 17:49 -
What brand of TV will play MKVs with VOBSUBss on a USB stick?
By Moralez in forum SubtitleReplies: 7Last Post: 17th Jun 2020, 01:22 -
Mac Book Pro: Make full length videos and put them on a USB stick?
By MagicDrop in forum Newbie / General discussionsReplies: 7Last Post: 3rd Oct 2018, 15:51 -
Old usb memry stick change created fails
By Budman1 in forum ProgrammingReplies: 4Last Post: 10th Jun 2017, 12:54
