Hi,
I was wondering if Soften block noise in TMPGenc at 35/35 really does anything significent in VCDs? The reason im hesitent to use soften block noise is because I don't want the movie to become blurry. I don't know how blurry that option really makes movies, but if the blurryness is hardly noticeable and you get a signifigent increase in quaility it might be something to try.
I used to use 30/30 for my VCD's and it made them pretty "soft" (blurry) but pretty much eliminated any block noise from high-motion scenes. It won't give you a significant increase in quality -- unless you think blurry is better than blocky
Personally, I prefer slightly blocky in motion scenes over blurry throughout the entire video.
Event Pan/Crop Dialogue Box Tab, revert to Dialogue Box?
By saiiyu in forum EditingReplies: 2Last Post: 10th Feb 2014, 15:26 -
Will my store-bought DTA box do the same thing as a Comcast DTA box?
By locust78 in forum DVB / IPTVReplies: 7Last Post: 25th Feb 2013, 18:26 -
Check where Maxell are from.
By Regor21 in forum MediaReplies: 10Last Post: 1st Jun 2011, 07:43 -
Check this out!
By mikee55 in forum Off topicReplies: 6Last Post: 18th May 2007, 11:17
