  1. Is VapourSynth R57 broken somehow? At first I blamed Windows 11's new termimal for the very slow throughput (slow pipe transfer?), but nope, even using ffmepeg with -vapoursynth, the process is extremely slow, using CPU for only like 25%. Both QTGMC and MCTemporalDenoise seem to grind to a near halt. All on my new i9 12900K. This used to go blistering fast, even on my old 6700K.
    Here's what I do (see below). It's almost as if multi-threading is broken for these two functions (it isn't, but appears to work exceedngly inefficient). This is 4K material, btw.
    import vapoursynth as vs
    import havsfunc as haf
    core = vs.core
    core.max_cache_size = 65535
    vid = core.dgdecodenv.DGSource (r'c:\jobs\am.dgi', ct=44, cb=44, cl=0, cr=0)
    vid = haf.QTGMC (vid, InputType=1, Preset="Very Slow", TR2=3, EdiQual=2, EZDenoise=0.5, NoisePreset="Slower", TFF=True, Denoiser="KNLMeansCL")
    vid = haf.MCTemporalDenoise (vid, settings="very low", stabilize=True)
    vid = core.neo_f3kdb.Deband (vid, preset="veryhigh", dither_algo=2)
    vid = core.std.AddBorders (clip=vid, left=0, right=0, top=44, bottom=44)
    vid.set_output ()
    E-cores are hardly used (some are marked as 'parked' even). But even the P-cores hardly see any action. See:
    CPU saturation
    N.B. I had the same issue on my previous i7 11700K, btw.
    P.S. Does it matter my plugins folder has 148 plugins in it? (all 64-bit recent vapoursynth plugins someone posted here).
  2. Assuming you:
    a. made sure to disable any anti virus etc. (or at least added execptions for file input folder etc.) to be sure that it's nothing like that
    b. your system isn't thermal throtterling
    benchmarking the script with vspipe and '--filter-time' should help to see which filter slows down the script the most,...
    "path to VSPipe" --filter-time "path to script" NUL
    should work.
    Cu Selur
  3. Originally Posted by Selur View Post
    Assuming you:
    should work.
    Cu Selur
    Cool, thx. These are rhe results of ca. 5 minutes of movie time:
    Output 7215 frames in 4836.29 seconds (1.49 fps)
    Filtername           Filter mode   Time (%)   Time (s)
    DFTTest              parallel       236.04   11415.38
    Degrain3             parallel       153.59    7428.12
    Analyse              parallel       140.13    6776.88
    Analyse              parallel       139.92    6766.79
    Analyse              parallel       135.95    6574.87
    Analyse              parallel       134.19    6489.61
    Analyse              parallel       133.42    6452.38
    Analyse              parallel       131.75    6371.89
    Degrain1             parallel        76.81    3714.79
    Degrain1             parallel        76.38    3694.15
    Analyse              parallel        59.43    2874.38
    Analyse              parallel        59.07    2856.85
    Degrain1             parallel        42.95    2077.16
    Super                parallel        42.45    2053.03
    Compensate           parallel        37.70    1823.22
    Compensate           parallel        37.16    1797.00
    KNLMeansCL           parreq          36.76    1777.75
    TemporalSoften2      parallel        34.00    1644.15
    Super                parallel        31.56    1526.36
    Super                parallel        30.51    1475.59
    Super                parallel        25.62    1239.13
    Compensate           parallel        24.76    1197.31
    Compensate           parallel        24.47    1183.26
    Compensate           parallel        24.47    1183.21
    Compensate           parallel        24.18    1169.34
    TemporalSoften2      parallel        22.21    1073.95
    resample             parallel        18.60     899.78
    TTempSmooth          parallel        18.35     887.22
    resample             parallel        17.68     854.87
    Deband               parallel        15.32     740.92
    Super                parallel        12.12     585.95
    Expr                 parallel         9.82     474.90
    Expr                 parallel         8.71     421.06
    Expr                 parallel         8.30     401.20
    Expr                 parallel         7.56     365.69
    Expr                 parallel         7.47     361.42
    Point                parallel         7.30     352.99
    Expr                 parallel         7.16     346.42
    Expr                 parallel         7.13     344.99
    Expr                 parallel         7.06     341.45
    Expr                 parallel         7.01     339.19
    Expr                 parallel         6.79     328.22
    Expr                 parallel         6.78     327.71
    Merge                parallel         6.73     325.45
    Expr                 parallel         6.73     325.34
    Expr                 parallel         6.69     323.71
    Merge                parallel         6.36     307.75
    MakeDiff             parallel         6.29     303.96
    Merge                parallel         6.26     302.53
    Merge                parallel         6.23     301.09
    MergeDiff            parallel         6.21     300.25
    Merge                parallel         6.19     299.49
    Convolution          parallel         6.18     298.65
    MergeDiff            parallel         6.10     295.05
    MakeDiff             parallel         6.02     291.36
    Convolution          parallel         5.97     288.95
    MaskedMerge          parallel         5.85     282.99
    Expr                 parallel         5.84     282.41
    Inflate              parallel         5.70     275.67
    Deflate              parallel         5.61     271.28
    Merge                parallel         5.51     266.49
    Inflate              parallel         5.36     259.19
    Deflate              parallel         5.28     255.32
    Expr                 parallel         5.25     254.09
    DGSource             unordered        5.18     250.73
    Expr                 parallel         4.98     241.04
    Minimum              parallel         4.63     224.13
    Maximum              parallel         4.63     223.72
    Minimum              parallel         4.60     222.57
    Minimum              parallel         4.59     221.93
    Maximum              parallel         4.56     220.74
    Maximum              parallel         4.56     220.34
    Minimum              parallel         4.55     220.16
    Minimum              parallel         4.51     217.99
    Minimum              parallel         4.51     217.94
    Super                parallel         4.49     217.20
    Maximum              parallel         4.46     215.60
    Minimum              parallel         4.41     213.16
    Maximum              parallel         4.37     211.56
    Maximum              parallel         4.32     208.95
    Maximum              parallel         4.29     207.35
    Minimum              parallel         4.27     206.58
    Maximum              parallel         4.22     204.18
    MakeDiff             parallel         4.20     203.26
    MakeDiff             parallel         4.19     202.86
    Minimum              parallel         4.16     201.38
    Maximum              parallel         4.13     199.86
    Crop                 parallel         4.13     199.63
    MakeDiff             parallel         4.06     196.45
    Median               parallel         3.98     192.53
    MakeDiff             parallel         3.96     191.64
    Convolution          parallel         3.95     191.13
    Inflate              parallel         3.95     190.91
    Convolution          parallel         3.94     190.69
    MakeDiff             parallel         3.93     190.28
    Convolution          parallel         3.93     189.94
    bitdepth             parallel         3.89     188.22
    Expr                 parallel         3.86     186.72
    bitdepth             parallel         3.85     186.14
    Convolution          parallel         3.68     177.99
    Convolution          parallel         3.53     170.95
    Convolution          parallel         3.50     169.11
    Lut                  parallel         3.46     167.12
    AddBorders           parallel         3.32     160.49
    PlaneStats           parallel         2.84     137.48
    Interleave           parallel         0.04       1.89
    SetFieldBased        parallel         0.01       0.44
    SCDetect             parallel         0.00       0.22
    SelectEvery          parallel         0.00       0.13
    ShufflePlanes        parallel         0.00       0.04
    Trim                 parallel         0.00       0.01
  4. Okay, then look at what happens if you don't use just QTGMC and then add the additional filters one at a time and later ony by one and also look at the speeds of the encoding.
    This should help to understand where bottelnecks are located, also check the speed without deinterlacing, may be QTGMC already slows down your processing so that any further processing doesn't really matter in regard to speed and cpu usage.
    Cu Selur
  5. Well, the matter is resolved. Looks like it was the E-cores, after all. I found a very useful option in the BIOS to disable the E-cores, pressing ScrollLock while in Windows 11 (it doesn't actually disable them, just marks them all as 'parked'). Now I get a blistering fast, sustained 100% CPU saturation again on all P-cores.
    Even though heretofore the E-cores appeared to be hardly used at all, nonetheless they were the source of the (significant) hold-up
