    Mar 2004
    Long Island NY
    Hello. I've been creating 5.1 FLAC files from multi tracks which have always worked flawlessly. Recently I added 2 more speakers to my system so I attempted to create a 7.1 multichannel FLAC file but regardless of the order in which I place these additional 2 tracks, there is no audio coming out of the speakers & my receiver still reads 5.1 PCM. I don't know if flac only has a 6 channel limit or if it's an issue on Kodi's end which is what I use to play them.
    Can anyone chime in, appreciate it !
  2. DECEASED
    Jun 2009
    Heaven
    After many years of lazyness the creator of FLAC finally added proper multichannel support to the FLAC format.
    The attached sample file is played correctly on my Windows 7 setup.
    Maybe you're right and the actual problem is Kodi.
    "Programmers are human-shaped machines that transform alcohol into bugs."
    Mar 2004
    Long Island NY
    I figured out the issue. In my receiver's speakers configuration, I have it set to 5.1.2 (the .2 being the 2 Atmos ceiling speakers I recently added).
    When I changed the configuration to 7.1 it worked, so every time I'd want to playback a 7.1 FLAC file I'd have to change the speaker layout from 5.1.2 to 7.1 so it isn't really worth it. Thanks for your help though!
