hlo there is there anyone here will explain how audio and video compression works?
suppose i have a raw audio file which is recorded at 8 bit per sample/bitdepth and 44,100hz containing only 1 channel
so its bitrate will be around 352.8kbit/s i guess
so if i compress and rencode this file with libopus codec at 128kbit/s
then what data will be removed from raw audio??
bit depth and sample rate will remain same?
for video i dont know the formula of calculating raw video
AnonymousGuest
Go read some books about information theory, signal processing, and data compression.
Start with:
https://en.wikipedia.org/wiki/Discrete_cosine_transform
https://en.wikipedia.org/wiki/Motion_estimation
https://en.wikipedia.org/wiki/Entropy_encodingLast edited by jagabo; 9th Jan 2022 at 11:23.
Perhaps somebody may be brave enough to start describing coding methods - but this is very wide topic where having strong math background may be necessary to explain priniciples.
This is associated with many factors - but mostly lossy audio compression will try to exploit human audio system characteristic - some signals are masked, some signals less audible, some signals not absolutely necessary to be present in reconstructed spectrum.
sample rate yes, bit depth not necessarily
bits per pixel (components number * bitdepth) * number pixels * number lines * number frames -
AnonymousGuest
...Or remove more data, which will be noticeable, but the loss might be considered acceptable for those circumstances.
Is there a lossless video capture card that also captures 5.1 audio?
By end-user in forum Capturing and VCRReplies: 121Last Post: 15th Oct 2022, 06:41 -
Is there any benefit to converting lossy to lossless.
By jpvoodoo in forum Video ConversionReplies: 3Last Post: 11th Jun 2021, 10:20 -
Lossy and Lossless compression: Is one format better than the other?
By Guernsey in forum Newbie / General discussionsReplies: 6Last Post: 11th May 2021, 05:36 -
AVStoDVD black screen video but audio works
By Petter O in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2020, 15:05 -
Capturing ffmpeg RAW or Lossless Video & Audio
By TubeBar in forum Video Streaming DownloadingReplies: 3Last Post: 24th May 2018, 02:11
