Basically while looking around my parents old items I found some old camcorders, one of them being the one titled, but theirs some problems, the main one being that I don't know if the camera is somehow broken or the battery on it is, because when I plug it in, it'll turn on. But when I leave it off to charge, I can tell on the side that it's charging, but the battery doesn't go up, no matter how long it's charging for. Is the problem most likely the battery and needs to be replaced? Other question is if I'm able to transfer the videos to my computer and what's needed for that.
Does the camcorder runs off of the AC adapter without battery? Most likely the battery is dead due to age, They make dummy battery adapters just lookup your camcorder model.
How do you connect this camera to the TV? You will need at least - as a bare minimum to start with - some "video capture device" which can be a card in the PC or, probably easier these times, an external USB adapter like the Hauppauge USB-live 2 to convert the analog signal from the camera to a digital format, plus a SW which runs on the PC for capturing.
There are plenty of posts and threads in this forum about capturing of analog video. Be prepared for a steep learning curve. -
Video 8/hi8 Tape playback colour cast issue -SONY Camcorder
By davo_whitey in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 26th Mar 2021, 23:21 -
Digital Zoom / Resolution Question
By markburgle in forum Newbie / General discussionsReplies: 9Last Post: 14th Aug 2020, 03:21 -
Sony TR920e Hi8 video camera
By Kajaboss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 19th Mar 2020, 06:33 -
Digital HI8 to Imac
By pablobandini in forum MacReplies: 2Last Post: 13th Oct 2019, 12:38 -
Sony Hi8 capture and conversion to digital format.
By RJPiekos in forum Capturing and VCRReplies: 4Last Post: 7th Feb 2017, 04:27
