Results 1 to 30 of 32
  1. Hi
    I can't find the license url nor the PSSH in the correct format
    [Attachment 62812 - Click to enlarge]
    [Attachment 62813 - Click to enlarge]
    maybe this website uses another encryption system
    could someone guide me a bit
    Nov 2015
    Campuchia - Sapoche
    video link, login data and vpn to playing this video ?
  3. Do not send me DM's
    Dec 2021
    Tórshavn
    Originally Posted by filipino View Post
    Hi
    emelogger via greasemonkey should get the pssh
    license url differs from site to site, you'll need to use different search criteria like token, acquire, drm, widevine, license, method:POST (since dramax is turkish, maybe an latin wrangling of a turkish word for license or token) It's hit and miss, lad.
    EDIT: in your second screen shot you have the mpd header up, look throgh for the common encryption segement, and see if there is a line beginning with <cenc:kidxxxxxxx>
    if so, post the cenc:kid too, that can supply the pssh
  4. Originally Posted by filipino View Post
    The pssh is in your second screenshot.
    See urn:uuid:
    the value after it is in hexadecimal
    Go to https://www.base64decode.org/
    Paste that value into the box > hit Decode
    and you will have your pssh in Base64
    For the lic url RIGHT click on your highlighted entry and select Copy > Copy url
    Looks like it has a suffix attached (string) that will change / time expire so you need very fresh one.
  5. Originally Posted by codehound View Post
    See urn:uuid:
    Ok I have this line: <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed" value="Widevine">
    within it I select edef8ba9-79d6-4ace-a3c8-27dcd51d21ed
    [Attachment 62819 - Click to enlarge]
    the result is some strange symbols
  6. PSSH
    AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEO3vi6 l51krOo8gn3NUdIe0=
    Nov 2015
    Campuchia - Sapoche
    from this link
    https://www.dramax.tv/watch/Gunes%25202/283
    im get mpd
    https://dramax-vod.ercdn.net/clr/Y/vl/gunesin-kizlari-s1-b2-spa/gunesin-kizlari-s1-b2-spa.smil/manifest_mpm4sav_mvnumber_high.mpd
    KID --> DF099606-F5B6-45FC-B761-0A2830683C42 change to DF099606F5B645FCB7610A2830683C42
    Using get pssh from KID
    Please input KID in hex string: DF099606F5B645FCB7610A2830683C42
    PSSH AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEN8Jlg b1tkX8t2EKKDBoPEI=
    lic url
    https://wv-proxy.ercdn.com/api/erproxy
    Work with WKS here is content key
    --key df099606f5b645fcb7610a2830683c42:c90ddb2e3635c974d aed140c2e65b798
  8. Originally Posted by therain View Post
    from this link
    im get mpd
    Grazie
    there are some things that i don't understand, for example: I want to get the
    curl command to paste it in https://curlconverter.com/
    where did you get that info from?
    Nov 2015
    Campuchia - Sapoche
    Example for chrome
    right click on (lic url) --> copy --> copy as curl (bash) then Convert curl commands to Python
    try with method here and you need cdm working
    https://forum.videohelp.com/threads/404263-Failing-to-download-on-ITV-Hub#post2643001
  10. Originally Posted by codehound View Post
    PSSH
    sorry i'm a bit rude on this, explain to me how is the way I should put the code in https://www.base64decode.org/
    I've already tried a thousand ways
    must be around here, but I don't know how you do it
  11. Originally Posted by filipino View Post
    PSSH
    The PSSH should be the inner text of that ContentProtection element, but it's not there in either screenshot. I'm equally curious where codehound got that from in your second screenshot. edef8ba9-79d6-4ace-a3c8-27dcd51d21ed is not the PSSH.
  12. Do not send me DM's
    Dec 2021
    Tórshavn
    PSSH
    It looks like a kid, but not sure if it's THE kid needed
    Actually, it's the wrong length for kid, scratch that.
  13. Originally Posted by Sorenb View Post
    It's not a KID - it's the uuid of the widevine DRM system. It's the same in every MPD for the WV ContentProtection element.
  14. here is the whole image, There are other play ready values but I don't know if they work
    I'll try emelogger via greasemonkey
    [Attachment 62825 - Click to enlarge]
  15. Originally Posted by filipino View Post
    None of these are correct ^^ and I dont know what this is (?)
    Forget Playready too
    In Dev tools > filter url for MPD > click on it > 'open in new tab' > this will download it > open it in Notepad++ and post it here please
  16. Originally Posted by codehound View Post
    mpd.txt
  17. @filipino
    It has been explained umpteen times how to get the pssh.
    This is getting to be ridiculous. These is a definite need for stickies in the channel so that this is not explained ad infinitum.
    Here we go and hopefully for the last time.
    how to get pssh
    1) Check the manifest
    look for this widevine identifier edef8ba9-79d6-4ace-a3c8-27dcd51d21ed
    look for this characteristic b64 id .... A7e+ and
    pssh>AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABIiClVTXzI0OTg1NTBI49yVmwY=</cenc
    If not found go to 2
    2) Install Tampermonkey plus the eme add on. Refresh the browser and check the console. If not found go to 3
    3) Download and search the init.mp4
    open the init.mp4 in a hex editor and search for the widevine identifier hex string edef8ba979d64acea3c827dcd51d21ed and the pssh value 70737368
    Capture 8 bytes before the pssh ... 000000xx70737368...... to end oh file. [xx is a checksum]
    If your don't like this then use mp4dump.
    if no pssh found in test 1, 2 or 3 then you have to create it from the kid which will be provided in the mpd manifest.
    There are umpteen python scripts that parse the manifest or create the pssh from the kid. Seems everybody and their mother wrote one.
    With respect to the post, I downloaded the init.mp4 and capture the pssh
    Correct pssh : AAAANHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABQIARIQ3w mWBvW2Rfy3YQooMGg8Qg==
    Check value:
    Widevine Pssh
    "algorithm":"AESCTR",
    "keyIds":["3wmWBvW2Rfy3YQooMGg8Qg=="]
  18. @filipino
    Please resist from posting such lengthy nonsense as it annoying to scroll through. Everyone had already seen the manifest. Don't know what you are trying to prove.
    Cease and Desist Thank you.
  19. lmao. he gets asked to post the MPD, proceeds to do so, and then gets jumped on with a rude response.
    nice.
  20. mpd.txt
    I fixed so it doesn't look so long, that's how jack must like it
  21. Originally Posted by filipino View Post
    [Attachment 62832 - Click to enlarge]
    Hindi mo paba nafifix? bigay mo mpd url
  22. Originally Posted by zackmark29 View Post
    vain attempts
    https://dramax-vod.ercdn.net/clr/Y/vl/gunesin-kizlari-s1-b2-spa/gunesin-kizlari-s1-b2-...umber_high.mpd
  23. Originally Posted by filipino View Post
    vain attempts
    Try
    init:
    https://dramax-vod.ercdn.net/clr/Y/vl/gunesin-kizlari-s1-b2-spa/gunesin-kizlari-s1-b2-...o=3500000.dash
    [Attachment 62835 - Click to enlarge]
    Well looks like the license required token/cookies/payload. That PSSH should work if you are doing it correctly.
  24. Originally Posted by zackmark29 View Post
    vain attempts
    Try
    init:
    thank you finally I am understanding, Do I use a script that I don't know or the Tampermonkey extension with EME to find a pssh ?
  25. Originally Posted by filipino View Post
    vain attempts
    Try
    init:
    EME should be enough if pssh is available from manifest but in your case, it's needed manual process by downloading the init url and extracting pssh manually with hex or other script (If there's available)
    That script I'm using is custom made by me without any use of like mp4dump (not yet public)
  26. Originally Posted by zackmark29 View Post
    Can you share the script please? Extracting pssh from init mp4 manually is so much hassle!
  27. Originally Posted by zackmark29 View Post
    Yes, it surely needs some modification, headers are just not enough. How can I determine the needed token/payload/whatever for this licence server?
    Can you please tell what exactly you did to get this key? Headers alone don't work for me. Did you do something extra? Can you please tell? I asked you via PM too but you never answered
    I always get a "405 Method Not Allowed" error with WKS-KEY or widevine_keys (yes I have a working L3) What modification needs to be done for this server can you please help?
  28. Originally Posted by Sorenb View Post
    Hey, Soren, when trying to find the License URL (and getting many results), how do you know when you have found the CORRECT License URL?
    Thanks!
  29. Got the same issue with v2.videoland.com
    there doesnt pop up a license url, u can search with thing like cenc, drm, widevine, lic but nothing
    the pssh i got is:
    AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEHNj5m f8MbeNq+AzjOqRc0Q=
    maybe someone can help me with the license url?
    thanks in advance
