hi,
i recently use yt-dlp to backup few youtube and odysee videos channel
it works like a charm with youtube
and it works very slowly with odysee, but at least it works
but impossible to find any software to works with crowdbunker videos
i mean i can use ant video dowwnloader or video download helper, but it's very not convenient to download video 1 by 1
is there a software or a way to create a CMD or powershell batch to automatically download crowdbunker videos channel same as with yt-dlp?
cheers
Results 1 to 19 of 19
You can batch download with yt-dlp
https://github.com/yt-dlp/yt-dlp#filesystem-options
And you can speed up downloads by multi-threading
Or by putting aria2c in the same dir as yt-dlpCode:yt-dlp -N 32 "mpd-url"
https://www.mediafire.com/file/h16fq91bpzk0lhp/aria2c.exe/file
But not both......Code:yt-dlp --external-downloader aria2c "mpd-url"
thanks for the multithread and/or aria2c advice, i will try
if i can give an advice too to everybody here, it's to use this batch command :
yt-dlp.exe https://xxxxxxxxxx --download-archive FILE.txt
in this way if you want again download this video channel few weeks later, thanks to the FILE.txt file, yt-dlp will not download again same files again, but only the new one, super convenient
and no crowdbunker not works with yt-dlp i am afraid
[Attachment 62802 - Click to enlarge] -
Whats so unique about crowdbunker that yt-dlp cannot download from it ?
Are you feeding it the right url ?
You're just feeding it the page url.
"It wont down from crowdbunker"Code:yt-dlp -N 32 --referer "https://crowdbunker.com/" "https://d.video-cdn.divulg.org/cb-medias4/videos/01FRQJW9BRMBQSEA5EVPQPKPCN/720p-x264-7AjB.m3u8"
[Attachment 62803 - Click to enlarge]
i don't know what's wrong about crowdbunker
i am sure about the URL, i already download all those CSI videos one by one last week with the two firefox videos addon i said above
but i notice there are many other interesting video channels on this website, and honestly i have not the time or courage to go again to download many video there one by one, or maybe i will do but i really hope i can find a better solution
seems crowdbunker is really anti censorship, seems they protect so much their videos from governements to not delete them, that at same time they also protect too much their videos from normal people to download them ^^ -
i have to admit i download much more faster with your multithread advice
i will see within 5 minutes if those 4000+ part frag files will become at the end a big beautiful video file
forgot to said that even with the 2 video addon for firefox, i had to download 2 files per video, one for video and one for sound, and had to merge them manually for each video with mkvtoolnix, was not convenient at all
yes now i can try to batch, after i understand how you found those 720p videos url from crowdbunker -
Click video Playback quality and change it from default 480p to 720p
Open dev tools and filter url for m3u8
Right click on 720p entry > Copy > Copy url (in Firefox)
[Attachment 62804 - Click to enlarge]
If you have any merging issues its easily solvable, although yt-dlp defaults are different to youtube-dl (if u used that before it died.)
Plus put ffmpeg in same dir as yt-dlp
https://www.mediafire.com/file/mv3ffex88q6z3ef/ffmpeg.exe/fileLast edited by codehound; 7th Jan 2022 at 19:16.
i confirm the 3990 temp files have become a single video file, and speed download was perfect, but no sound
but it's ok, i also found where you found those urls with ant video downloader, i will add audio urls in the batch too
about merging at the end all videos files with audio files do you have an idea?
seems there is -multistreams option with yt-dlp, but never tried it, in worst case it's ok i think i will find a way with mkvtoolnix
now i am going to play how to use batch with yt-dlp
really a BIG THANKS to you!!! with this forum i feel to suddenly have reach an higher skills levels
i thought i was not bad to know how to download manythings, but your answers teach me humility ^^
oh i just see your answer how to find those urls, 1000 thousands thanks again -
My bad --------- you need this m3u8
[Attachment 62805 - Click to enlarge]
Plus put ffmpeg in same dir as yt-dlp (important)
Done - 720p Video + FR Audio and combined - 2 minutes total ))Code:yt-dlp -f 799+audio1-Francais -N 32 --referer "https://crowdbunker.com/" "https://d.video-cdn.divulg.org/cb-medias4/videos/01FRQJW9BRMBQSEA5EVPQPKPCN/5-7AjB.m3u8"
[Attachment 62806 - Click to enlarge]
General
Complete name : C:\Users\xxxxx\5-7AjB [5-7AjB].mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 1.71 GiB
Duration : 2 h 11 min
Overall bit rate : 1 860 kb/s
Writing application : Lavf58.76.100
Video
Format : AVC
Format profile : Main@L3.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference : 4 frames
Codec ID : avc1
Source duration : 2 h 11 min
Bit rate : 1 594 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 47.952 (47952/1000) FPS
Minimum frame rate : 24.000 FPS
Maximum frame rate : 12 288.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.036
Stream size : 1.46 GiB (86%)
Source stream size : 1.46 GiB (86%)
Writing library : x264 core 155 r2917 0a84d98
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 257 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 241 MiB (14%)
Default : Yes
Alternate group : 1Last edited by codehound; 7th Jan 2022 at 20:01.
thanks again, i am trying now, seems your solution works again perfectly good, very impressive
just before your last message i even didn't manage to download manually the audio part with videodownloadhelper, i don't know why it has download only half time of the audio
then yt-dlp give me the 10054 error
but now seems everything works fine again
really thanks again for all your advices, so far i didn't found any message on any forum about crowdbunker & yt-dlp, so you will soon be a famous hero if you are the first answer from google congratulations
it was very interesting but it's 2:00 am here i need to go to sleep now
very happy to have discover this forum and you -
Hi again, I try to use all your advices above to download other videos channels on crowdbunker, but i still don't understand where you find this "799+audio1-Francais" ?
so i have try to find other solutions and done researches on "yt dlp postprocessor args ffmpeg Merger" and write both video and audio url in batch, it's downloading correctly the audio file and the video file, but can't merge them
if it's too complex to explain don't worry i will still use mkvtoolnix manually, but i have to admit it's hard to come back to my complex and slow process after have used your super effeciency code -
Use the yt-dlp FORMAT command - note capital F
Note you may need a fresh m3u8 - one from yesterday may be expired.
To see available formats. Different VODs and different channels may all have different available formats.Code:yt-dlp -F --referer "https://crowdbunker.com/" "https://d.video-cdn.divulg.org/cb-medias4/videos/XXXXXXXXXXXXXXXXXXXX/5-7AjB.m3u8"
Then use the -f command (note lowercase) to download your required formats.
What is this inklara ? A yt-dlp lesson ? ; )Last edited by codehound; 8th Jan 2022 at 04:46.
oh thanks again , now i have again the 10054 error so i can do nothing, but i will try again later, you are very impessive !
inklara, at least in my heart, means: into the light
if you want it's also one way to say i am out of the darkness
which means a lot to me during this last few months of covid and try to deeply understand what is really happening (for example those CSI video, if you understand french speaking, help a lot to understand daily covid news but from a viewpoint without any corruption)
honestly at the beginning i just did few reasearch to make my choice between doing covid injection or not, then i have discovered so many things behind this covid, things that i have even no idea it's even exist, now i can't stop to do researches about that and everything that has link to that, it's very interesting, but sometimes give also headaches, or sad feeling, it's also not 100% sure to know who speak right and who speak wrong, it's also why i continue my researches, to find the truth, to know how to recognize the truth
even if i understand exactly what's happening it will change nothing about what will happen next (new world order, etc) but at least, at the end, i feel less puzzled when i heard "official" news -
Peace out ))
Note you may need a fresh m3u8 - one from yesterday may be expired -
yes it's what i thought, but seems my problems now is more link to 10054, and it always disappear by itself after few minutes or hours, so i just wait
and yes peace, and strength to humans
if everybody in politics and science was as efficiency as you, covid would have already disappear after only few days
actually if we are on this forum it means we like computer stuff, so we should be happy the new world order will transform slowly but surely humans to kind of cyborgs, but when i see all the lies around covid it's harder to feel positive about our future, but it's an other subject which would needs hours and days of debate (debate which is by the way almost completely forbidden now if you dare to think in an other way than our gouvernements)Last edited by inklara; 8th Jan 2022 at 06:37.
Need help for download with yt-dlp
By sibhus in forum Video Streaming DownloadingReplies: 26Last Post: 19th Feb 2024, 16:02 -
Help with yt-dlp
By Loryanam2 in forum Video Streaming DownloadingReplies: 1Last Post: 5th Jan 2022, 12:57 -
Help with yt-dlp downloads
By jeffo in forum Video Streaming DownloadingReplies: 3Last Post: 3rd Dec 2021, 18:40 -
yt-dlp will not download in ts format
By Skaperen in forum Video Streaming DownloadingReplies: 21Last Post: 19th Nov 2021, 20:45 -
DLP Chip
By biferi in forum Newbie / General discussionsReplies: 1Last Post: 8th Apr 2021, 16:53
