Hi,
I'm having problems even playing (let alone re-encoding) the m2ts files on a new bluray disc I just bought.
Can any of you help me to find the right codec to play, I've tried tons of programs and downloaded many codecs in the hope of finding one that worked but to nothing has worked so far.
Here is a small m2ts from the disc:
https://www.dropbox.com/s/ffb0vobhxfvwr0j/00002.m2ts?dl=0
That file will not help since it is not a valid video file. It is just either random data or relies upon a playlist within the blu ray.
Select the largest file and upload a mediainfo (text mode) report. Possible, of course, that you have not ripped the disk correctly. -
Thanks for the answer!
I simply copied the files directly from the disc to my I see now that I need a dedicated app to rip the bluray disc, so I will experiment with that now. Thanks
Pico projector video files- desperate to find a compatible codec!
By salukikev in forum Video ConversionReplies: 3Last Post: 25th Oct 2021, 17:54 -
Cannot find the CODEC in your system to decompress this AVI file.
By strawberryshortcake in forum Software PlayingReplies: 2Last Post: 28th Sep 2020, 14:59 -
Cannot find x264 codec device for FFmpeg transcoding
By Tom Ato in forum ProgrammingReplies: 2Last Post: 13th Feb 2020, 15:00 -
Can't find the codec for a very old .AVI video!
By maucvs in forum Software PlayingReplies: 14Last Post: 28th Dec 2018, 15:47 -
Cant find the codec for this video
By supercain in forum Video ConversionReplies: 8Last Post: 25th Dec 2018, 22:51
