id like to get these bin files ranging from 730-770 MB and when trying to do a image burn with nero 5.5 it says the media is not large enough. Am I missing something? Before I write the cd i notice within the info tab it says the full size is over 2 GB.
If I cant burn it how do I convert it to a mpeg file. I do have the cue file and have cahnged the path for the bin.
PLEASE HELP.
are you going FILE -- BURN IMAGE and then loading up the cue sheet?
as this will work even if the bin file is over 700mb because bin files are always bigger than actualy burn. -
Nero 5.5.0 does not handle Bin/cue files correctly. It always reports the file disk is too small. Use a later version, a least 5.5.76. If you are using the latest version then try using CDRDAO or CDRWin software instead.
I always use Nero to burn .binfiles w/ no problems at all.
First of all open the cue in notepad and the bin in Nero (file-->burn image).
Then a new windown will popup, in that window make sure that the numbers are as the cue file you did open in Notepad.
If so press burn.
Done to have fun :P
USiT
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
Help with large TS file
By mejallen in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2010, 19:44 -
large iso file
By fabpozzi in forum Authoring (DVD)Replies: 10Last Post: 13th Dec 2008, 12:10 -
Large .dvr-ms file?
By ukcat in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2007, 15:47 -
.cdr file on a DVD+
By jamesmarcustucker in forum Video ConversionReplies: 1Last Post: 6th Sep 2007, 07:13
