Results 1 to 10 of 10
    May 2011
    I included a sample of the full video (H264/AAC). It seems there are duplicate frames in the interlaced source: probably an A B C C frame pattern (every third frame is duplicated). Using QTGMC generates even more duplicates. So, what Avisynth instructions to use to properly deinterlace it and to retain as many good frames as possible?
  2. Hmm,..
    • video is vfr: argh
    • video is flagged progressive
    • decoding the video with LibavSMASHSource and DGDecNV I see no combing artifacts
    • video has aliasing issues
    • video seems oversharpened
    -> deinterlacing seems to be the wrong approach
    (using Vapoursynth down scaling to i.e. 1440x1080 and upscaling using RealESRGAN, SwinIR probably can help with that strong aliasing)
    sadly this is not a fixed pattern.
    If the main goal is to get rid of dublicates the best way is probably to use dedup and create vfr output, see: http://avisynth.nl/index.php/DeDup
    Alternatively something like filldrops might be interessting,...
  3. It's supposed to be 60fps progressive. Lot of dropped frames from frame 154 onwards. The duplicates get inserted in place of the dropped frames in order to keep the 60fps playback speed (audio sync). The capture is crap. Too many dropped frames in a row to fix it with interpolation.
    May 2011
    Yes, this clip is messed up. I wrote this script and it gives reasonably good results (way less aliasing issues thanks to QTGMC's filtering) considering the source:
    file="Tove Lo - Outside Lands Festival, USA, 2017.mkv"
    SetFilterMTMode("QTGMC", 2)
    LWLibavVideoSource(file)
    TDecimate(cycle=4)
    QTGMC(Preset="Slow", fpsdivisor=2)
    Prefetch(threads=4)
    The frame rate dropped to 22.058 fps but somehow it's less choppy because of less duplicates. Could this script be improved or should I go with it?
  5. Well, if you are happy with what you got .....
    You still would need to synch the audio though. Good luck.
  6. BlankClip() will clean it up nicely.
    May 2011
    Can you elaborate how to use it for this video?
  8. Originally Posted by elektro View Post
    It's an alternative to the trashcan
  9. Yes, I was being flippant. The variable frame rate makes it near impossible to get smooth motion out of it.
  10. @elektro: you may want to try with this script:
    # DeJump.avsi
    # mod 2021-07-12 by JKyle
    # An AviSynth filter that smooths out jumps and drops
    # - Based on script created by Didée
    # - Modified by John Meyer on June 29, 2011
    # - Further modification by John Meyer on June 8, 2013
    # https://forum.videohelp.com/threads/402416-repair-Videos-with-duplicates-and-dropped-frames#post2625132
    # - Transformed into DeJump filter function by JKyle on July 12, 2021
    #    - parametrized input clip, `jumpthresh`, and `thresh` (for `FillDrops`)
    #    - parametrized `num` and `den` options for `double` via `MFlowFps` to take input clip properties
    #    - removed `ShowMetrics` function needed for test
    #    - removed `FillDrops` function to make use of the externalized function script `FillDrops.avsi` (mod by Selur)
    #    - unglobalized and internalized some variables to be used in `GenerateMask`: `jumpthresh`, `blackframe`, `whiteframe`
    ### Requirements ###
    # MvTools2 (https://github.com/pinterf/mvtools)
    # MaskTools2 (https://github.com/pinterf/masktools)
    # TIVTC (https://github.com/pinterf/TIVTC)
    # FillDrops mod 2021-07-10 by Selur (https://github.com/JJKylee/Filter-Scripts/blob/main/AviSynth/FillDrops.avsi)
    ### Arguments ###
    # jumpthresh (default=0.88) - Threshold for detecting jumps
    #    Increase to catch more jumps.
    #    Should always be less than 1.0
    # thresh (default=0.4) - Luma Difference Threshold for FillDrops
    # showdot (default=false) - Troubleshooting
    #    true for troubleshooting; otherwise, false
    ### How this filter works ###
    # Create interpolated frames a 2x original frame rate using MVTools2
    # Detect jumps
    # Create white mask at each jump point; black mask for all other frames
    # Repeat each frame of original video and use mask to "choose" between original video, or motion estimated video
    # Decimate exactly 50% to get back to original frame rate.
    # This decimation removes the dup frames from the original video and also the dups created by repeating each frame of original video
    # However, at each point where motion-estimated frame was inserted, no decimation occurs. Thus, if dups=drops, and the drop happens
    # within < "cycle" (TDecimate parameter) of the dup, the dup will be removed and the drop will be filled.
    # If no drops or dups occur within "cycle," then no motion estimation happens, and decimation merely gets back to original,
    # unchanged video.
    function DeJump (clip c, float "jumpthresh", float "thresh", bool "showdot")
        jumpthresh  = Default(jumpthresh, 0.88)
        thresh      = Default(thresh, 0.4)
        showdot     = Default(showdot, false)
        source = c.ConvertToYV12.KillAudio()
        newnum = c.FrameRateNumerator * 2 # Added for double (JKyle)
        newden = c.FrameRateDenominator # Added for double (JKyle)
        blackframe = BlankClip(source, color=$000000)
        # removed internalized `whiteframe` (JKyle)
        super = showdot ? source.Subtitle("***").MSuper(pel=2) : source.MSuper(pel=2)
        bvec  = MAnalyse(super, overlap=0, blksize=16, isb=true, search=4, dct=0)
        fvec  = MAnalyse(super, overlap=0, blksize=16, isb=false, search=4, dct=0)
        double = source.MFlowFps(super, bvec, fvec, num=newnum, den=newden, blend=false)
        #Generate a white or black frame, depending on frame difference
        bwmask = GenerateMask(source, jumpthresh)
        #Generate the 2x framerate mask needed to choose the motion-estimated frames
        themask = Interleave(blackframe, Trim(bwmask, 1, 0))
        #Merge double framerate from original with motion-esimated frames, but only where there are jumps
        #(i.e., original frames are used except at jump points)
        Interleave(source, source).mt_merge(double, themask, luma=true, U=3, V=3)
        #Decimate
        RequestLinear
        decimated = TDecimate(display=false, mode=1, cycleR=10, cycle=20)  #Decimate half of all frames (set to twice the length of "normal" dup/drop cycle)
        # some repeats are still left after decimation, so fix those as well
        final = FillDrops(decimated, thresh)
        return final
    #This function returns a white clip whenever a big jump is detected; otherwise a black clip is returned
    #Each YDiff must eliminate Ydiff=0 (duplicate) from moving average
    # `jumpthresh` argument added for internal use (JKyle)
    function GenerateMask (clip c, float jumpthresh)
        blackframe = BlankClip(c, color=$000000) # internalized for GenerateMask (JKyle)
        whiteframe = BlankClip(c, color=$FFFFFF) # internalized for GenerateMask (JKyle)
        mymask = c.ScriptClip("""
        \ (( (YDifferenceFromPrevious(SelectEvery(c, 1, 2)) < 0.3 ?
        \       YDifferenceFromPrevious(SelectEvery(c, 1, 3))  :
        \       YDifferenceFromPrevious(SelectEvery(c, 1, 2)) )
        \    (YDifferenceFromPrevious(SelectEvery(c, 1, 1)) < 0.3 ?
        \     YDifferenceFromPrevious(SelectEvery(c, 1, 2))  :
        \     YDifferenceFromPrevious(SelectEvery(c, 1, 1))  )
        \    (YDifferenceFromPrevious(SelectEvery(c, 1, -1)) < 0.3 ?
        \     YDifferenceFromPrevious(SelectEvery(c, 1, -2))  :
        \     YDifferenceFromPrevious(SelectEvery(c, 1, -1))  )
        \    (YDifferenceFromPrevious(SelectEvery(c, 1, -2)) < 0.3 ?
        \     YDifferenceFromPrevious(SelectEvery(c, 1, -3))  :
        \     YDifferenceFromPrevious(SelectEvery(c, 1, -2))  )
        \     )/4) /
        \    (YDifferenceFromPrevious(c) + 0.01) <= jumpthresh
        \ ? whiteframe : blackframe """)
        return mymask
