Why "Screen Record" (Desktop video capture in VLC) does not save video file. After press "Stop" button a video file with 600 bytes size saves! Video input mode is "Automatic" and all others are as default. I have not changed them.
Any help?
Results 1 to 10 of 10
screen:\\
Capture mode: Desktop
FPS: set to 15
Convert settings: H.264+MP3 (MP4)
Save directory: DesktopLast edited by ten; 4th Jan 2022 at 22:39.
Have you looked here?
https://www.videohelp.com/software/sections/desktop-screen-capture
Perhaps CamStudio -
No! But I know there is ton of "Screen Capture" apps out there on the web like OBS, SnagIt, FSCapture, Adobe Captivate, XBox Game Bar (Windows native reorder) and ...
I need to know what is wrong with VLC to solve it and use it as screen recorder (I use it as player and converter). I don't want to install new app, just keeping my OS minimalist!! -
It works for me, follow these instructions
https://www.fonepaw.com/recorder/record-screen-and-video-with-vlc.html -
Try "Destination File' to a real place on your hard drive instead of "Desktop". (like the sample shows in the fonepaw link)
Make a new folder first and name it something you will remember and save to that. Let us know if that works.Extraordinary claims require extraordinary evidence -Carl Sagan -
My guess is the audio and video streams are disabled in VLC's capture/convert settings. Use MediaInfo to get a report on what's in the file.
Desktop is fine for VLC output. The Desktop is just another folder in Windows. Usually C:\Users\username\Desktop.
ffmpeg screen recording
By qo4on in forum Video ConversionReplies: 0Last Post: 29th Dec 2021, 19:55 -
Can you Help me find if this is a Real Web-dl or just a screen recording ?
By Loryanam2 in forum Video Streaming DownloadingReplies: 5Last Post: 24th Dec 2021, 20:15 -
What is wrong with my screen recording?
By navarannan in forum Video Streaming DownloadingReplies: 32Last Post: 2nd Jun 2020, 12:36 -
Screen recording using VLC
By gastrof in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2019, 13:24 -
Advice for screen recording on Windows 7?
By nobodyhome in forum Video Streaming DownloadingReplies: 3Last Post: 3rd Aug 2017, 17:51
