Results 1 to 11 of 11
  1. Hello!
    I'm trying to download a movie from an mpd file (https://7tskp6kbcx.singularcdn.net.br/MANIVA/FILMES/LUTAR_LUTAR/FILME-2021-12-16T22%3A...A59/stream.mpd) using YoutubeDl . But I only get this error:
    [generic] stream: Requesting header
    WARNING: Falling back on generic information extractor.
    [generic] stream: Downloading webpage
    [generic] stream: Extracting information
    ERROR: No video formats found; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
    Is it possible to download this?
  2. Do not send me DM's
    Dec 2021
    Tórshavn
    use this
    https://github.com/yt-dlp/yt-dlp
    and use yt-dlp -F --allow-u <mpd.url>
    see:
    yt-dlp -F --allow-u https://7tskp6kbcx.singularcdn.net.br/MANIVA/FILMES/LUTAR_LUTAR/FILME-2021-12-16T22%3A19%3A59/stream.mpd
    WARNING: You have asked for UNPLAYABLE formats to be listed/downloaded. This is a developer option intended for debugging.
             If you experience any issues while using this option, DO NOT open a bug report
    WARNING: [generic] Falling back on generic information extractor.
    [info] Available formats for stream:
    ID                                   EXT RESOLUTION │   TBR PROTO │ VCODEC        VBR ACODEC     ABR  ASR    MORE INFO
    aca745d8-7a81-4517-971e-cf81ea5add92 m4a audio only │  128k dash  │                   mp4a.40.2 128k 48000Hz [pt-BR], DASH audio, m4a_dash
    77c56607-e482-4caf-b3c5-7124c04e45c3 mp4 854x480    │ 1200k dash  │ avc1.4D401E 1200k                        DASH video, mp4_dash
    59b4b521-5960-4439-97ee-0f9dbd7eed43 mp4 1280x720   │ 2400k dash  │ avc1.4D401F 2400k                        DASH video, mp4_dash
    8642fa4d-addc-4ab8-a553-542b11eeef11 mp4 1920x1080  │ 4800k dash  │ avc1.4D4028 4800k                        DASH video, mp4_dash
    and use yt-dlp -f to select the video and audio formats, or simply yt-dlp --allow-u <mpd.url> to download the defaults
  3. after download need key to decrypt ...
    content is encrypted
  4. Originally Posted by Sorenb View Post
    use this
    see:
    Thanks man. Worked perfectly!
    But as lomero said below, the video is unreadable, certainly because it's encrypted. Is this key located in the mpd file?
    Sorry for the questions, but this is my first time doing the procedure.
    Thank you guys!
  5. no, key isn't on mpd
    is reply by server when you play video.
    to get this key you must follow a procedure. on this forum there are a lot of posts about this, just read.
    anyway it's not something you can do, not knowing what we're talking about.
    so, if you need key to decrypt your video, you must write your video link and login data
  6. Thanks for the clarification lomero. At the moment I don't have access to the video, as it had been rented. I will check the posts on key recovery. When I have access to the video again, I resume the thread.
    Thanks!
  7. Lutar, lutar, lutar (Strive, Strive, Strive )
    Documentary film about the Brazilian football club Atletico Mineiro
    Download the English subtitles here https://olharplay-delivery-2021.s3.amazonaws.com/MANIVA/FILMES/LUTAR_LUTAR/LEGENDAS/LU...R_LUTAR_EN.vtt
    the pssh required to get the keys is
    AAAAVHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADQIARIQYJjhgVoEUKmQNS2W03x2WRoIbW92aWRvbmUiEGdsnv6BjmdMsE87vD/mc8UqAlNE
    Now send us the top url (referer url) i.e. the one from which you obtained the mpd. We need to get the License (Server) URL
    This may be a bridge too far for a beginner but this is a one shot deal, so you should get help here.
  8. Originally Posted by jack_666 View Post
    Thanks for the answer, jack_666!
    The key you found was in the mpd file, right? I lost access to the video because I had rented it and my access time expired.
    I got the URL of the mpd file by analyzing the network stream in the browser, the last time I watched it. I think I'll probably have to rent the video again to get the key, right?
    Anyway, these are the URLs I saved:
    https://www.salamaniva.com/filme/lutar-lutar-lutar/
    https://www.salamaniva.com/4e6d603f-4be6-4381-8c84-e41e84f544b5
    https://7tskp6kbcx.singularcdn.net.br/MANIVA/FILMES/LUTAR_LUTAR/FILME-2021-12-16T22%3A.../fmp4/init.mp4
    https://7tskp6kbcx.singularcdn.net.br/MANIVA/FILMES/LUTAR_LUTAR/FILME-2021-12-16T22%3A...00000/init.mp4
    https://7tskp6kbcx.singularcdn.net.br/MANIVA/FILMES/LUTAR_LUTAR/FILME-2021-12-16T22%3A.../segment_0.m4s
  9. nooooo. key isn't from mpd!
    from mpd have maybe KID but need key to decrypt
    final key is KID:key
  10. Hello lomero! Maybe I can get KID:key if I rent the movie again and analyze network traffic for it? Is that the case?
  11. no. don't spend your time.
    it's no easy. and for you it's impossible to get this key.
    you need to know a lot of stuff about python and network traffic from your pc and server hosting your video.
    the only possibility you have is write here the link to your video and write a PM (to those who offer help) with your login data
