i would like to record my desktop to a file in some standard format (webm preferred). i'd like a choice for the audio channel to be: 1. whatever is playing. -or 2. whatever the microphone picks up. -or 3. nothing (silence).
"recording" to a connectable port would be a nice addition. something ffmpeg can connect to is preferred.
my display is 1920x1080. so i would expect HD/2K.
				Results 1 to 12 of 12
	Never needed it, but OBS (https://obsproject.com) is probably worth a look. users currently on my ignore list: deadrats, Stears555, marcorocchini
	vokoscreen works fine
 https://linuxecke.volkoh.de/vokoscreen/vokoscreen.html
	both of those look like more than just recorders. they look like video editing and/or production tools. they look like way more complicated than i can deal with, right now. maybe someone who actually uses one a lot can tell me what the steps are to just record my whole 1920x1080 display to a video file (with a 1920x1080 video stream). the simpler, the better. preferred would be a command so that i can integrate it into a script that gets run. and what if i want to start recording an application that has already taken over the full screen?
	would any of these work ?? - https://itsfoss.com/best-linux-screen-recorders/
	that site is putting YT video windows over what i try to read. the only button on them is the YT "SKIP ADS" button. i can't read it.
 supposedly ffmpeg can do this but it never works for me. try the very first example here https://trac.ffmpeg.org/wiki/Capture/Desktop
	i finally got ffmpeg to record video (the example had a hardcoded DISPLAY value that at first i did not recognize as such. now that i have "$DISPLAY" ir succeeds recording video. it's probably going to the wrong place for sound, but i know no way to list choices and see no way to choose one.
	Using Kubuntu 20.04 here and version 0.4.4 of SimpleScreenRecorder. I suggest you update.i just tried it a couple hours ago using version 0.3.8 packaged for Ubuntu 18.04. video recorded good but there was no sound.
 The should be a sound settings window where you can select the sound source and format, if you them go to the preview screen you can monitor the audio levels below the picture.
 Brian.
	turns out there is an audio source menu. it has only 2 choices, there is also a refresh button, presumably to update the choice menu. i clicked "Refresh" and got this:
 i don't understand why it has "alsa". i have Pulse chosen. could this be the problem?Code:[PulseAudioInput::GetSourceList] Generating source list ... [SourceNamesCallback] Found source: [alsa_output.pci-0000_00_1b.0.analog-stereo.monitor] Monitor of Built-in Audio Analog Stereo [SourceNamesCallback] Found source: [alsa_input.pci-0000_00_1b.0.analog-stereo] Built-in Audio Analog Stereo
 i tried both, playing a video that has sound (i can hear the sound while Firefox is playing the video from YouTube). neither worked. is it possible that YouTube is doing something to block recording of sound to make recording of music impossible?
  Seagate Expansion DesktopBy kyrcy in forum ComputerReplies: 22Last Post: 17th Sep 2020, 15:10
  Question About Recording Video Desktop?By MadMaxnightRider in forum Video Streaming DownloadingReplies: 13Last Post: 1st Jan 2020, 00:36
  Using and old server as a desktop machine,... (need help)By Selur in forum ComputerReplies: 12Last Post: 29th Dec 2018, 01:27
  Record Desktop Activity ...how?By MourningStar in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2018, 20:35
  Converting VHS to DVD desktop pcBy oduodui in forum Capturing and VCRReplies: 3Last Post: 30th Apr 2017, 08:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
