Hello, thanks in advance for any help, and Happy 2022.
I'm trying to learn how to batch remove-clear all of multiple .mkv files' individual tracks "Track name:"s using either MKVToolNix GUI's "Job output\When finished..." feature with either mkvpropedit.exe or a .bat file, or just a .bat file. Heck, any way other than individually. For clarity:
1) Multiple jobs are queued in MKVToolNix GUI (v64.0.0) and will be created in a single folder.
2) The only fields I want cleared are the individual tracks' "Track name:" (as seen in "MKVToolNix GUI\Multiplexer\Input", the bottom, left box "Tracks, chapters and tags").
I've searched high and low but can't find a solution and if I've posted this question in the wrong place then I apologize.
This worked on a couple of test files.
I did NOT try it with multiple audio or subtitle tracks, so I don't know the correct parameters.
You'll need to experiment.
Remove by stream type and number.
e.g. the movie has 1 video, 1 audio and 1 subtitle stream.
--track-order
0:0, is video
0:1, is audio
0:2 is subs
--track-name 1: - refers to the audio track
--title "" - deletes the contents of the title tag - for the audio track
Cheers.Code:@echo off :: Process all MKV in a folder. if not exist New\*.* md New for %%a in ("*.mkv") do call :process "%%a" goto :end :process title "%~n1" "C:\Program Files\MKVToolNix\mkvmerge.exe" --ui-language en --output "New\%~1" --track-name 1: "%~1" --title "" --track-order 0:0,0:1,0:2 goto :eof :endLast edited by pcspeak; 6th Jan 2022 at 13:04.
I use this to wipe all metadata. And chapters.
Cheers.Code:@echo off :: Clear all metadata if not exist New\*.* md New for %%a in ("*.mp4", "*.mkv") do call :process "%%a" goto :end :process ffmpeg.exe -i "%~1" -map_chapters -1 -map_metadata -1 -metadata title="" -metadata comment="" -map 0 -c:v copy -c:a copy -c:s copy -y "New\%~1" goto :eof :end pauseLast edited by pcspeak; 6th Jan 2022 at 14:31.
Thanks for your reply (and patience), pcspeak. And apologies for my ignorance, but I'm not quite sure how to apply the above "scripts". Thanks for any additional information.
EDIT: After having the time and focus, I was able to make the first .bat file work (I had to change the path for mkvmerge.exe). Thanks for that! Unfortunately I can't figure out how to make the second .bat file work. I receive the error message "'ffmpeg.exe' is not recognized as an internal or external command, operable program or batch file." I tried changing the "ffmpeg.exe" to the path of my ffmpeg.exe but receive a "Permission denied" error after many lines of text that I understand as words but not their contextual meaning
Last edited by LouieChuckyMerry; 12th Jan 2022 at 15:51. Reason: Information. Information.
Hi, in searching for this topic i end creating a powershell script
The script gets all the mkv files in the current and sub directories then iterates over each file and get the total tracks of the file, with this info the script iterates over each track and edit its name.Code:Get-ChildItem -Path . -Recurse -Filter *.mkv | ForEach-Object { $mkvFile = $_.FullName $baseMkvName = $_.BaseName $totalTracks = (mkvinfo.exe $mkvFile | Select-String "Track ID" | Measure-Object).Count Write-Host "The file $baseMkvName has: $totalTracks tracks." for ($i = 0; $i -lt $totalTracks; $i++ ) { $trackID = $i + 1 $newTitle = "Track: $trackID" mkvpropedit.exe $mkvFile --edit track:$trackID --set "name=$newTitle" Write-Host $newTitle } }
I hope it helps anyone searching for ideas for this kind of topic.
<3 -
cosmicuser: I just noticed your comment. Would you, please, be willing to explain to me how to use your script? I'd very much appreciate it
Batch rename audio tracks like so "[Codec] [Language] [Channels]"
By aur0n in forum AudioReplies: 0Last Post: 19th Jul 2021, 19:52 -
Program to cut M2TS file into clip with all tracks "un-touched"
By kpic in forum EditingReplies: 2Last Post: 12th Dec 2018, 13:20 -
BATCH remove audio track from mkv
By MarquisdeOz in forum AudioReplies: 53Last Post: 30th Jul 2018, 08:48 -
"Restore SDR" or "Remove HDR" its possible?
By danfgtn in forum Newbie / General discussionsReplies: 7Last Post: 7th Jul 2018, 15:33 -
Sony Vegas - Can you "fine tune" tracks?
By Xanadu2 in forum EditingReplies: 3Last Post: 21st Dec 2017, 15:47
. For clarity:
