  1. Hello
    this site uses the same KID and key to download any video from your page, I would like to modify the script so that you do not need a cdm ni all that implies looking for a key
    and insert the kid and key into the script
    this is the script:
    https://github.com/weishang9/************************r
    I would appreciate it so much for your help
  2. what makes you think the site uses the same kid:key for all their content? and if that's indeed the case, you don't need that script anymore. you can just write a simple python script to decrypt your video.
  3. Originally Posted by maicdy View Post
    that's how it is, the site uses the same kid: key for all its content
    I have basic knowledge of python
  4. if you have basic knowledge of python you will at least be able to modify it. a quick scan on blimtv.py should give you a hint that def DecryptVideo, def def DecryptAudio, def getKeyId needs to be modified based on your assumptions.
    some parts may also need to be removed/commented out since you don't need to actually get keys (again, assuming your claim of kid:key being all the same is correct).
    no one's gonna edit the script for you
  5. I have only learned to use I can only use the pip command, xd
  6. @filipino
    If I understand you correctly, you already have the kid:key. Well if this is the case the I would suggest you use parnex dl script.
    https://github.com/parnexcodes/widevine-L3-WEB-DL-Script/blob/method-2/webdl.py
    set up a keys.txt file with contents kid:key
    If you are unable to understand this script, then I would suggest you try google and do some searches. This parnex script is infinitely easier than modifying HBO-MAX-BLIM-TV-Paramount-4k-Downloader.
  7. Originally Posted by jack_666 View Post
    @filipino
    I'm already learning how to use it, thank you very much
