Hello all,
I have made a dvd made with Panasonic dmr-e75v. A ‘Record from vhs to dvd apparat.’
When I put this dvd in my computer all I see is 1 big .udf file. (a dvd full)
Question: How can I see the (self recorded) video on the dvd?
settings for recording were ok I think, I used a recommended dvd-, and the dvd was finalized. (after a loooong search on how to do that)
Or did something go wrong? How can I know?
What would the file extension be normally?
I know for sure it worked (for my friend), so it is not dued to the apparat itself.
Thanks for any help provided.
Does your DVD recorder have an option to FINALIZE the DVD disK? See if you need to close the disk sesison then put in a cmoputer to see.
Panasonic DVD recorder passthrough settings (DMR-ES10, DMR-ES15, DMR-ES25)
By Brad in forum Capturing and VCRReplies: 462Last Post: 21st Aug 2025, 06:33 -
DVD created on Panasonic DMR-ES35V does not show on PC
By Inger in forum Capturing and VCRReplies: 17Last Post: 11th Dec 2021, 01:47 -
Panasonic DMR-ES15 DVD Drive Intermittently Works
By alitek12 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jun 2020, 00:15 -
Panasonic DMR ES35V DVD NoRead repair
By Lumpy2 in forum DVD & Blu-ray RecordersReplies: 32Last Post: 9th Jul 2018, 21:15 -
Is it possible direct recording on dvd r with Panasonic dmr ex768
By nusratjaveid in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Aug 2017, 12:40
