Hi,
I'm trying to run some video game consoles through this Vidbox NW07 using OBS.
I can get composite video to work smoothly after installing the drivers from the VidBox website, but when I plug anything into the s-video port, there's no video.
Is there a setting I need to change? Or something in an ini file to force input from the s-video?
I don't have a CD with a product code to get the video conversion for PC, I just bought the little box.
Thanks!
You need to change the input type in the cross-bar, If the driver doesn't show it you will need to lookup "cross-bar thing".
OBS Video Captures with DisplayPort Emulator
By nicksteel in forum Video Streaming DownloadingReplies: 0Last Post: 9th Aug 2021, 14:11 -
What are the FFMPEG settings codes for Ut video in OBS?
By Truthler in forum Capturing and VCRReplies: 1Last Post: 2nd Dec 2020, 10:09 -
Honestech VIDBOX compatible video capture software? I lost the disc!
By DF001 in forum MacReplies: 5Last Post: 21st Jun 2020, 21:34 -
VIDBOX or Elgato Video Capture for Mac.
By jmv in forum Capturing and VCRReplies: 0Last Post: 13th Sep 2019, 17:18 -
inconsistant video seeking from OBS studio records
By Golem in forum Newbie / General discussionsReplies: 16Last Post: 10th Apr 2019, 11:33
