Hi folks!
Well, need your advice on something.
How can I tell if a svcd .mpg file was encoded as NTSC or PAL?
Reason I ask is I cant seem to find anything that can show
the properties of the .mpg's in question, giving me a headache
when trying to burn them in Nero. Im not sure whether to use the
NTSC or PAL setting!
Recently I burned a svcd .mpg onto a CD as I didn't think it had
a chance of being PAL coz it simply isn't around in the UK yet, I used
NSTC as the setting in Nero, yet when I played it back on my
DVD player, fine for awhile but some weird green squares and clashing......so back to the drawing board I burned as PAL!! This time
no problems at all......how the hell can this be? I dont think there
was any chance in hell this file was encoded as PAL. Hmmmmm!
I've never had this prob before playing back NTSC stuff on my DVD player!
HELP ME!!
Need.....program.....to....tell ....me....whether....file.......is......ntsc....or .....pal! ....***Stuttereds words as its hard destroying freshly burned stack of cup coasters as well as typing***
"If hustling is deviance in the eyes of the lord, then in my realm he is blind"...B*Tip - Back in the day!
Look in the tools section. Either download a software dvd player or get an mpeg2 codec. Play the svcd in media players, right click and choose properties. Look through its properties and find its resolution. Check here http://www.vcdhelp.com/svcd.htm to see what the ntsc and pal resolutions are for svcd.
Or just download VCDEasy and have it analyse the file.
MPEG2, PlayingTime=184.884s, Bitrate=2788800bps, PtsOffset=0213s, 25849 packets
Video Stream: Motion Video, 480x480, 29.97003fps (NTSC), 2520kbps
Audio Stream: Audio Standard MPEG layer2 Stereo, 44100Hz, 229376bps
Xvid bitrate and file size problem - Heeelp!
By Salinas in forum DVD RippingReplies: 0Last Post: 10th Mar 2010, 17:05 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
just got my first vidcam; a Panasonic HDC HS9 and after info on MPEG2 TS
By topcatstudios in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2009, 22:08 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03
