Hello! New user here. Making a family video from 2021 and when I cut a particular video clip, it makes a pop or a click noise at the spot where it's cut. I silenced the whole video as I'm putting it to a soundtrack and no other cut video makes this noise. I've deleted the video and re-cut it in various spots, but it makes no difference. How can I fix this?
How do you silence video?...would have thought that was for audio.
But seriously, video doesn't make a pop/click, audio does. So however you may THINK you are silencing a track, you must not be doing it fully or properly.
However, using an edit tool that doesn't have builtin transition click supression will greatly raise the probability that you will encounter this not uncommon phenomenon. You should be able to manually zoom in to a few frames and do a crossfade or similar mix at each cut site, but with the wrong project and the wrong tool, that can turn out to be a lot of work.
Give us more detailed info...
Noise detection in video
By ValentinNikin in forum ProgrammingReplies: 0Last Post: 4th May 2021, 10:26 -
Looking for help removing noise from a video
By jasonx3 in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2020, 14:06 -
VHS video noise
By Maris 55 in forum Capturing and VCRReplies: 31Last Post: 21st Jul 2018, 09:48 -
Video distortion/noise
By latouffe in forum Capturing and VCRReplies: 10Last Post: 24th Mar 2018, 07:44 -
Video Edit - Cutting a section of video from a larger video file
By bpatters69 in forum EditingReplies: 14Last Post: 10th Nov 2017, 10:33
