my research and conclusion is
1 channels = mono = 1 signal for all speakers
2 channels = streo = 2 signals(1st signal for left and 2nd signal for right) for all speakers
more channels is used to create sound effects like car is moving right to left
but also more channels makes file size bigger
Results 31 to 33 of 33
Anonymous543Guest
Where the sound goes depends on what speakers you have and how the amp is set up. Mono may only be sent to the front center speaker. Or to both the front left and front right speakers, or all three front speakers. Or to all speakers. Stereo may be sent to the front left and front right speakers. Or all three front speakers. Or, when left and right channels are identical, only to the front center speaker. When the left and right channels are exactly 180 degrees out of phase the sound will be sent to the rear left and rear right speakers, or the rear center speaker on systems so equipped.
Left to right can be done with stereo. More channels add front/back placement and ambient effects (echo, reverb, etc.).
Not necessarily. With uncompressed or losslessly compressed audio more channels make for bigger files. But with bitrate based encoding (mp2, mp3, ac3, aac, etc.) the bitrate determines the size. 2 channels at 448 kbps is the same size as 6 channels at 448 kbps. Stereo mp3 at 384 kbps is the same size as stereo ac3 at 384 kbps.
The definition of bitrate is:
For audio size is usually expressed in kilobits and time in seconds, so you get kilobits per second, kbps.Code:bitrate = size / time
So when you specify the bitrate you're actually specifying the size (since the running time is fixed). Simple algebraic manipulations gives:
For example, 60 seconds at 128 kbps:Code:size = bitrate * time
Of course, the full size of the file will be a little larger because there's a little container overhead.Code:size = bitrate * time size = 128 kbps * 60 seconds size = 128000 bits * 60 seconds size = 7680000 bits size = 960000 bytes (8 bits per byte) size = 960 KiloBytes or size = 937.5 KibiBytes
Alternatively to plain stereo you can use sofa filter and produce audio more suitable for headphone listening, i personally consider this as subjectively better.
Normal people has two ears and stereo is minimum to provide acceptable audio field - if you desperate to save bitrate then you can use mono.
Bellow sofa downmixing filter chain for ffmpeg:
Code:-af "aformat=channel_layouts=7.1,aresample=resampler=soxr:osr=48000:cutoff=0.99:dither_method=0,sofalizer=sofa=dodeca_and_7channel_3DSL_HRTF.sofa:gain=11:lfegain=9"
Splitting MPG stereo audio into one track per channel
By Quitch in forum Video ConversionReplies: 8Last Post: 25th Jul 2021, 04:21 -
Converting a stereo 116kbps Opus track to AC3; what bitrate should I use?
By broom441 in forum AudioReplies: 5Last Post: 8th Jan 2021, 00:09 -
Which Audio Track to Choose To Multiplex Down to STEREO?
By Pareto Optimal in forum DVD RippingReplies: 6Last Post: 22nd Aug 2020, 04:37 -
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 13:42 -
are there bugs in avidemux 2.6.21 additing audio & convert audio to stereo?
By rama in forum EditingReplies: 0Last Post: 7th May 2017, 05:06
