I'm practicing with it based on changing 'duration' manually in a baseline entry. Unfortunately I'm slow to pick up how to do this.
Results 31 to 33 of 33
No disrespect, but it seems like you're going round in circles. If you want some help post something specific,
instead of a bunch of abstractions which nobody can make head nor tail of. -
Agreed about going around in circles. I'm putting it down for a while-- at least with this project which seems so endless. Maybe later.
Subtitle Edit moves punctuations to the beginning of a line in batch mode
By Nicada in forum SubtitleReplies: 2Last Post: 11th Dec 2021, 16:19 -
Subtitle Edit - Split Long Lines in Tools menu vs. Batch Convert Option
By Verminaard in forum SubtitleReplies: 0Last Post: 13th Jul 2021, 04:55 -
Reliable method for inserting an empty line? (Subtitle Edit)
By Asterra in forum SubtitleReplies: 3Last Post: 18th Feb 2021, 15:34 -
Subtitle Edit - Check split lines when character limitation not met
By whatcrisis in forum SubtitleReplies: 3Last Post: 27th Dec 2020, 12:42 -
How to extract dvb subtitles from ts files using Subtitle Edit Command Line
By MounaLafi in forum SubtitleReplies: 0Last Post: 21st Jun 2019, 16:52
