I haven't used this machine for many a year it's been in the loft I actually thought it wouldn't work but I needed to try it with a certain vhs tape I have.
Anyway here is the setup and problem
VCR Panasonic NV-F200 = s-video out to ES10 AV4 in
ES10 = s-video out to Lite-on S-video in
Now this is where I am having trouble I hear sound but no picture
I tried this the other day with a Panasonic DMR-XS350 with no problems at all but I can't figure the connections settings with this machine do I have to use the S video with component for AV1 Output, then set AV2 Input S video with Ext Link 1?
I have tried a few options but I am not getting a picture through at all just sound.
S-Video out from the Panasonic is always active, it doesn't need to be configured. Edit: Except S-Video via Scart on European models.
Do you get see any of the Panasonic's own menus?Last edited by Skiller; 30th Dec 2021 at 19:10.
I can see all the settings inside the ES10
I have a scart in the scart out to the tv could this be causing an issue? I'm downstairs now so will remove it later if this will cause issues. -
Just to make sure, I was asking if you can see the Panasonic's menus via S-Video in your capture, not on the TV via Scart.
It shouldn't cause a problem if there's a TV connected on AV1. -
Right I'm back upstairs
To start from fresh I set the machine to default settings set it up like normal now I can see the ES10 settings via the S-video but I can only hear the sound and I am getting a grey screen.
Right I have sorted it complete knob head mistake lol I didn't put it on AV4 via the remote what a dick.Last edited by lojelo5; 30th Dec 2021 at 20:14.
Panasonic DVD recorder passthrough settings (DMR-ES10, DMR-ES15, DMR-ES25)
By Brad in forum Capturing and VCRReplies: 513Last Post: 5th Oct 2026, 06:16 -
Panasonic DMR ES10 (UK) needs power cord
By Cherbette in forum DVD & Blu-ray RecordersReplies: 18Last Post: 25th Sep 2019, 14:56 -
Panasonic DMR-ES10 - Broken?
By geordie10 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 9th Jul 2019, 12:49 -
Settings Panasonic DMR-ES10 for pass through
By GovertdeKat in forum Capturing and VCRReplies: 4Last Post: 17th Oct 2018, 12:58 -
Do I have the Correct DMR-ES10 Pass through Setup Right?
By TazDave in forum Capturing and VCRReplies: 7Last Post: 28th Feb 2018, 09:15
