Sorry in advance if this question has been answered previously. Hopefully I am asking a slightly different question. I have over 100 MiniDV tapes I need to transfer. I believe it might be cheaper to buy my own setup and do the transfer myself. I own a Windows Workstation Laptop, but it doesn't have a firewire port. So, I realize I need a PC with expansion slots and a video card with a Firewire port. I would appreciate recommendations on what to buy - Win PC specs for video transfer, Firewire card, and software. I could pay $10 per tape to hire a service to transfer this for me, so I guess I save money if the total cost of purchasing my own equipment is under $1,000. I can do editing on the workstation laptop, so I only need a PC powerful enough to handle the transfer. Thanks again for your suggestions.
i'd try somewhere like goodwill for a used workstation. check the back for a firewire port, or if it's running check the device manager for ieee1394.
[Attachment 62630 - Click to enlarge]
it really doesn't matter how fast/slow the computer is and windows 7/8.1 are fine and probably easier to work with the old winDV than newer windows. firewire doesn't rely on the cpu. a pentium 3 used to work just fine. what you will need is a decently sized hard drive as a 1 hour minidv transfers at 13GB to the drive.
what you don't mention is if you have a camcorder or deck to read the tapes with. miniDV tapes can hold different flavors of DV or HDV, some of which require special cams/decks to read.--
Just read this. Or search.
https://forum.videohelp.com/threads/402827-How-to-Capture-700-Mini-DV
MiniDV to PC via firewire audio problem
By borntalent in forum Capturing and VCRReplies: 37Last Post: 3rd Apr 2020, 06:07 -
[SOLVED] Strange problem with capturing MiniDV via firewire - missing audio
By The Big Cheese in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2019, 11:28 -
Suggested hardware specs when capturing MiniDV footage through Firewire?
By guy24s in forum Capturing and VCRReplies: 9Last Post: 26th Jan 2019, 05:16 -
Best free software to capture from a MiniDV camcorder WITH Firewire?
By kelemvor in forum Capturing and VCRReplies: 1Last Post: 6th May 2018, 22:48 -
PC never recognized Firewire, need 100 hrs of MiniDV tapes copied to PC
By randc64 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 1st Oct 2017, 17:07
