I have never burnt any vcds
i need to know do you need a certain amount of memory or mhz on your computer?? do you have to have a certain type of internet connection??
please tell me everything i will need to start burning vcds!!!
Also can these movies be burnt right now, SPIDERMAN, BLADE2, LORD OF THE RINGS, SCORPION KING, AND RESIDENT EVIL??
The best thing to do is Start reading the How to's on the left.
All depends on what you want to do? Want to capture video, back up DVD's?May the force be with you. -
Check to see if your player can play Mpeg-2s if can you just need to covert the AVI file to a MPEG-2Originally Posted by joker4499
