In Windows 10 default app for PDF is reset to Microsoft Edge despite associating to another app (with Open with > Choose another app > Always use this app to open .pdf files and under Settings > Apps > Default apps > Choose default apps by file type). I believe this is a known issue, but has anyone managed to find a solution that actually works?
				Results 1 to 11 of 11
	Use a different browser maybe? Extraordinary claims require extraordinary evidence -Carl Sagan
	I have PDF open in Firefox and it works without issues. (Windows 10 21H1)
 I also have default apps > web browser > Firefox
	I haven't tried Firefox, but prefer not to use a browser as default app for PDF.
	It is something to do with your system. I work daily with hundreds of win10 computers (usually more recent versions), and have not had any problem changing the default for pdf. And keeping it that way.
 A browser or os update will often reset the prefs, but it is pretty straightforward to re-reset them back. Done.
 I use a script using SetUserFTA.
	Right click on a pdf file, select properties, next to "Opens with" click the "change" button and change it to whatever you want i.e. Adobe Reader DC It's not important the problem be solved, only that the blame for the mistake is assigned correctly
	Associating to another app works briefly, but then default app for PDF is reset to Microsoft Edge. There are many threads in various forums about this issue, so this is not a unique problem with the system I am using. And the problem appears without performing any updates and without running Microsoft Edge.
	Maybe this would help:
 https://www.groovypost.com/howto/debloat-windows-10-with-windows-debloater/
 On this website, about half-way down, you can see this:
 You can enable or disable Cortana, Edge PDF takeover (where Edge takes over as your default PDF application), and enable or disable Windows Dark Theme.
	It may not be unique to your setup, but there is very likely a common thread to how you and those others are building their systems that is making it susceptible to this problem. Could be retaining an MS-centric background running process, could be running an app which does not follow modern Win OS rules that triggers a "needed reset", or could be a call to DISM in a script that requests a reset, etc. Lots of variables there, unfortunately.
 What I am saying is that it is fairly simple to build a system where this does not happen, as I do this on a regular basis.
 "Briefly"? Is that seconds, minutes, hours, days, weeks, months...?
 Just a wild guess, but might you be using a Home version of Windows? Bad idea.
  How to use Widevine L1 encrypted streams on Microsoft Edge?By calande in forum Video Streaming DownloadingReplies: 14Last Post: 12th Aug 2023, 10:11
  widevine decrypt extension for microsoft edge not workingBy takheang303 in forum Video Streaming DownloadingReplies: 6Last Post: 3rd Apr 2021, 12:46
  Microsoft Edge resets pdf association in Windows 10By kyrcy in forum ComputerReplies: 17Last Post: 10th Nov 2020, 13:28
  How do I convert PDF to JPG?By gary11364 in forum ComputerReplies: 34Last Post: 20th Jul 2017, 05:27
  Professional desktop app similar to Boomerang app? (Looping GIF)By savvyguy in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2017, 04:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
