Dear VideoHelp Forum Members,
Recently, I found a barely used JVC HR-S6900U S-VHS. The image output is generally clean, but the video has some white lines in some frames that caught my attention. After an attempt to clean the video head, the frequency of the white lines has decreased, but the problem persists.
Please, I ask for your help as this problem has been bothering me a lot and I don't know what to do. What puzzles me is that the cause of the problem shouldn't be the video head, as the previous owner said he didn't use the device much.
If possible, I ask for simple instructions as I could not find any professional in my city who would accept to carry out the VCR maintenance, the entire procedure must be done by myself.
Thanks in advance!
"Some white lines" is not very precise. A screenshot or a photograph of the VCR playing on a TV would help identifying the issue. The diagnosis is not obvious (yet) in case you expected that.
White lines usually means the heads are wearing if you did a good head cleaning.
Hi Skiller! Thanks for answering! And my apologies, now I see it's a vague description. It's hard to pause in a exact frame that displays the issue, so I ordered a capture card, as soon as it's delivered I'll attach an example.
Hello johns0! I appreciate your reply! Do you know a sure way to check if the heads are clean? Also, could you tell me that in case of wear, only a video head of the exact same model would work as a replacement?
yt-dlp + mdp: "Could not send HEAD request" - HTTP error 403: forbidden
By oopargentina in forum Video Streaming DownloadingReplies: 6Last Post: 27th Mar 2021, 10:01 -
Can "hunting" Comcast Motorola DVR be put in "playback only" mode?
By Jimw338 in forum Newbie / General discussionsReplies: 3Last Post: 14th Mar 2021, 12:48 -
Will a JVC VCR "Stop" Playback if the video is "too grainy" or degraded?
By timepassenger in forum Capturing and VCRReplies: 8Last Post: 2nd May 2020, 07:17 -
"No Signal" from capture card
By DonaldB in forum Capturing and VCRReplies: 10Last Post: 4th May 2017, 16:50 -
"Flaws" in SD signal being noticeable on higher resolution displays vs CRT
By 90sTV in forum Newbie / General discussionsReplies: 9Last Post: 9th Apr 2017, 21:53
