I've got a Pinnacle DC10+ capture card, running in a Duron 800, 192MB, 8 GigH/D. running VDub V1.4.10
What Iam trying to do is capture a uncompressed AVI using the following: (Thanx Maverik)
I set my capture res to 480x480 (not sure why this works, but it does).
1. Under Capture - Settings - I canged to frame rate to 29.97
2. under Video - Compression - I set to (No recompression: UYVY)
3. under Video - Set Custom Format - I set 480x480 uyvy yuv 4:2:2 interleaved.
4. under Audio - Compression - I set to DV Audio -- NTSC and 44.100kHz, 16bit, stero
5. under File - Set Capture File - Change this to where you want it to save the AVI and what you
wanna call it.
6. Capture.
My problem comes with the "No recompression: UYVY" setting all I can select, no matter what codecs ive loaded (got few in there now due to a format of the H/D) is one selection of "No recompression: MJPEG".
Is this a card type issue, a codec issue, or an ignorant newbie with the wrong settings somewhere issue LOL?
I never even thought of that :oops: , god Iam a F**k-en idiot, couldhave torn my hair out when I read read your reply.
Ah well back to the drawing board whith the best capture settings for it (decided to do all my capture in Studio).
Suppose this was a case of
Tis best to shut up and let people think you are an idiot, than to open it and remove all doubt.
In search for an uncompressed video capture card
By xyzxyz in forum Capturing and VCRReplies: 39Last Post: 24th Mar 2013, 07:45 -
PAL People with TV Tuners/Capture Cards - Uncompressed
By zerowalker in forum Newbie / General discussionsReplies: 75Last Post: 28th Feb 2012, 23:38 -
Uncompressed vs DV capture for noisy videos
By telefunken in forum Capturing and VCRReplies: 2Last Post: 6th Mar 2009, 05:33 -
Asking uncompressed component video capture solution for iMac (iO LA)
By perniente in forum MacReplies: 1Last Post: 6th Jan 2008, 20:22 -
JVC HR-S6970 or HR-S9500 for S-VHS capture (uncompressed to pc)?
By temp in forum RestorationReplies: 2Last Post: 3rd Sep 2007, 10:37
