Closed Thread
Page 1 of 8
1 2 3 ... LastLast
Results 1 to 30 of 227
  1. Welcome to How To Dump L3 CDM From Android Device's (ONLY Talk About Dumping L3 CDMS), i have started this to discuss this topic only!!
    A FEW Simple Questions:
    How can I Dump L3 CDM's from Android Devices?
    What Devices can i dump L3 CDM's from?
    How to Use Dumper?
    is it possible to DUMP L1 CDM's using Dumper??
    IF anyone knows how it is possible to DUMP L1 CDM's using Dumper??
    or IF anyone knows how it is possible to DUMP L1 CDM's?? PLEASE DM ASAP THANKS
  2. Originally Posted by Dannyboi View Post
    How to Use Dumper?
    https://github.com/widevinedump/LenovoTB-X505X-L1-KEY
  3. Please stop posting CDMs - all you're doing is speeding up how quickly they get blacklisted.
  4. Originally Posted by Dannyboi View Post
    How to Use Dumper?
    For starters you need an Android 10 or older (but not TOO old) and not a Samsung. You need to root it. From there follow the instructions on the Dumper page. You might need to modify the javascript part of Dumper to hook other functions - I did. If you need help with rooting, this isn't really the place for that. Head over to XDA Developers forum. Hope that helps a little.
  5. Script is for L3 only
  6. Oh yea, and make sure you don't try to use a carrier locked phone. You won't be able to enable OEM Unlock (required to unlock the bootloader for rooting) in most cases. I had to buy an older unlocked phone specifically for this.
  7. has anyone had success rooting and dumping l1 and or l3 cdms from T95 S1 Android TV BOX, Android 7.1?? ifso dm please
  8. psaframe
    Mar 2021
    Algeria
    How to Use Dumper?
    cdm is blacklisted now on NETFLIX & soon official revokes by google
  9. Originally Posted by Dannyboi View Post
    Follow the instructions I posted above and the L3 will dump from that box just fine (You shouldn't need to root as it shopuld be pre-rooted. You will need to ADB via WiFi)
  10. Originally Posted by T33V33 View Post
    ok thanks ill try when i get it
  11. Originally Posted by T33V33 View Post
    Good to know, thanks for the tip. Just ordered one for this purpose, will try when received and let you know
  12. Keep in mind I make no guarantees… just because it worked for me doesn’t mean it will simply work for others… there are variations other than the box that can come into play… different py versions, script variations, frida versions etc
  13. so i have my T95 S1 Android TV BOX device, connected to home wifi not pc wifi, pc connected to wifi and downloaded frida server and installed and its running on the T95 And its rooted, im getting
    File "C:\Users\Username\Desktop\Use for rooting & grabbing l3 cdm from android tv box\Dumper\dump_keys.py", line 21, in <module>
    libraries = scanner.find_widevine_process(device, process.name)
    File "C:\Users\Username\Desktop\Use for rooting & grabbing l3 cdm from android tv box\Dumper\Helpers\Scanner.py", line 149, in find_widevine_process
    process = dev.attach(process_name)
    File "C:\Users\Username\AppData\Roaming\Python\Pyth on39 \site-packages\frida\core.py", line 26, in wrapper
    return f(*args, **kwargs)
    File "C:\Users\Username\AppData\Roaming\Python\Pyth on39 \site-packages\frida\core.py", line 165, in attach
    return Session(self._impl.attach(self._pid_of(target), *args, **kwargs))
    frida.ProcessNotRespondingError: process with pid 12228 either refused to load frida-agent, or terminated during injection
    C:\Users\Username\Desktop\Use for rooting & grabbing l3 cdm from android tv box\Dumper>pause
    Press any key to continue . . .
    UPDATE...
    IM GETTING:
    2021-12-28 09:54:43 PM - root - 25 - INFO - Hooks completed
    UPDATE 2:
    only thing is the android tv box wont load any apps, websites or anything now
  14. Being stuck at hooks complete is not an error I’ve had to deal with so have no idea how to fix.
    If the box is not loading anything then something has gone wrong somewhere. Maybe try resetting it and starting again
  15. Originally Posted by T33V33 View Post
    i restarted everything same error 2021-12-28 10:48:05 PM - root - 25 - INFO - Hooks completed
  16. I would probably do a fresh setup, erasing to factory. If it shows only that line is because is not finding any processes at all let alone the Widevine process to hook the functions.
    Also consider doing a manual install of frida-server from here:
    https://frida.re/docs/android/
    When downloading the frida-server file, make sure is arm and not arm64
    You can connect remotely via WiFi using:
    "adb connect ip_of_you_tvbox:5555"
    You will need to enable USB debugging and attempt to run the above command before attempting to install Frida manually.
  17. Originally Posted by T33V33 View Post
    Yes of course. But if it worked for you, it's not hopeless
  18. UPDATE MANAGED TO DUMP L3 CDM now to do L1 SOMEHOW, if anyone knows plz DM Thanks
  19. Originally Posted by Dannyboi View Post
    I believe dumping L1 is far more complicated than L3... Its like running a simple script. I think since L1 is hardware based it probably requires some kind of exploit to be available for the device which also means only certain devices are possible?
  20. Originally Posted by T33V33 View Post
    hopefully someone here knows how to dump l1 cdms fingers crossed anyways only if it was as simple as running s script like dumper
  21. Originally Posted by Dannyboi View Post
    Sadly the few people I know who may (probably do) know how to do it have also made it clear that they are not willing to share the process - I assume probably to protect whatever exploit they're using
  22. Do not send me DM's
    Dec 2021
    Tórshavn
    l1 is definitely not going to happen on a device which needed it's bootloader unlocked to be rooted. If it's an oem approved unlock (See Xiaomi unlock https://en.miui.com/unlock/) or sony (I'm not au fait with current models, but in the xperia arc era, unlocking was a hardware hack and it wiped out the drm access.) you get a warning about certain functionality being unstable/unusable/insecure after the unlock is applied. Part of that insecure functionality disables banking apps from working with new secure protocols see any magisk forum over the past year for details, it's a big one. And another part is L1 widevine being disabled at oem unlock. Your wvdump with frida can't dump what isn't there.
    Obviously someone has found a way around this, working l1 keys got dumped publicly by an idiot and revoked.
  23. can anyone help getting the 1080p keys for this all4 tv show plz?? and post them here quoting this post or pm thanks
    main URL: https://www.channel4.com/programmes/guy-martins-lancaster-bomber/on-demand/72675-001
    mpd: https://ak-jos-c4assets-com.akamaized.net/CH4_08_02_900_72675001001001_001/CH4_08_02_9..._template=time
    license: https://c4.eme.lp.aws.redbeemedia.com/wvlicenceproxy-service/widevine/acquire
    im im getting is:
    license response status: <Response [403]>
    server reports:
    server did not issue license, make sure you have correctly pasted all the required headers in the headers.py. Also check json/raw params of POST request.
  24. Do not send me DM's
    Dec 2021
    Tórshavn
    im im getting is:
    server reports:
    How about post the main url, Channel 4 tokens are time limited, they expire quickly
    Also, in l3, there are no 1080p keys, there is simply a decode key which will work for all resolutions the mpd pulls out, being c4.
  25. Originally Posted by Sorenb View Post
    im im getting is:
    server reports:
    ok heres the url for the tv show please can u get the keys and add them below thanks https://www.channel4.com/programmes/guy-martins-lancaster-bomber/on-demand/72675-001
    please can u dm how u did it thanks
  26. Do not send me DM's
    Dec 2021
    Tórshavn
    im im getting is:
    server reports:
    KID:KEY -> 00000000000000000000000004277739:07eee2c5ddd4b8299 a8a765ac342c67c
  27. Originally Posted by Sorenb View Post
    im im getting is:
    server reports:
    that was fast thanks can u check your pm please thanks
    Video and Audio Decrypted thanks
  28. Originally Posted by Sorenb View Post
    im im getting is:
    server reports:
    Anychange u are able to decrypt my5 1080p Videos if i send u the 1080p mpd links plz?
    the 1080p MY5 Mpds are available to get via tv app by adding _1080p (after manifest) please DM ASAP Thanks
  29. Do not send me DM's
    Dec 2021
    Tórshavn
    I thought you had your own cdm keys?
  30. Originally Posted by Sorenb View Post
    i have l3 cdm yes but i cant seem to get keys for all4 for some reason only disney+ 720p so far using my tools, but my5 dont stream 1080p via website only via app
