can't help you with my5 app. not my concern. My5 app is obviously more secure compared to a browser, so quality will be shite on the browser.
Read dm for all4.
Closed Thread
Results 31 to 60 of 227
anyone knows what this means plz?
PSSH obtained.
AAAAZnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEYIARIQAA AAAAAAAAAAAAAABCl4dRoIcmJtY2g0dHYiJDAwMDAwMDAwLTAw MDAtMDAwMC0wMDAwLTAwMDAwNDI5Nzg3NTIA
license response status: <Response [403]>
server reports:
server did not issue license, make sure you have correctly pasted all the required headers in the headers.py. Also check json/raw params of POST request.
oi i got as far as adding the license url, mpd and pssh and its returning this error: so not my fault i followed his video step by step and its just sending this error back, and my5 streams 1080p via tv app yes on samsung appently but if u get the mpd and add _1080p after manifest you can download the 1080p manifest try it it really works!!!!!!!
server reports:
yes when you get the my5 tv mpd add _1080p and then download the tv episode in 1080p it works because i have loads of my5 1080p encrypted files but need keys to decrypt them, also saves downloading them later
can anyone help with these headers plz they arnt correct appently but i followed instructions but im using windows not linux, if this is wrong please correct and paste correct version asap thanks
import requests
headers = {
'Connection': 'keep-alive',
'sec-ch-ua': '" Not A;Brand";v="99", "Chromium";v="96", "Google Chrome";v="96"',
'DNT': '1',
'sec-ch-ua-mobile': '?0',
'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36',
'sec-ch-ua-platform': '"Windows"',
'Content-Type': 'application/json',
'Accept': '*/*',
'Origin': 'https://www.channel4.com',
'Sec-Fetch-Site': 'cross-site',
'Sec-Fetch-Mode': 'cors',
'Sec-Fetch-Dest': 'empty',
'Referer': 'https://www.channel4.com/',
'Accept-Language': 'en-GB,en-US;q=0.9,en;q=0.8',
data = {
'{"request_id":5270822,"token":"U2hHTmdoTlOWPoaCIY RMfeFuqPTnaiNhpVp6GStkEV6naRp3L48Aq5SYSdgFdbIT9YzN mvAou5NQYVbSxfZWsSfKR0H-cVJN4goW0N05mu11a-A_ErwbLhuuy4csT-DUjCPRF2G0JUs0VcUhRP5bgJ3ta6M7TZUT","video":{"type ":"ondemand","url":"https://ak-jos-c4assets-com.akamaized.net/CH4_08_02_900_72591001001001_003/CH4_08_02_900_72591001001001_003_J01.ism/stream.mpd?c3.ri': '13628487079128191530',
'filter': '(type=="video"&&((DisplayHeight>=288)&&(systemBit rate<4800000)))||type!="video"',
'ts': '1640820702',
'e': '600',
'st': 'qe9evJmKxiNWif4QGqpGcnrOEdzi56YsggcPLZc-2h8',
'mpd_segment_template': 'time"},"message":"CAQ="}'
response = requests.post('https://c4.eme.lp.aws.redbeemedia.com/wvlicenceproxy-service/widevine/acquire', headers=headers, data=data)
headers = {
'authority': 'drmtoday.vieon.vn',
'sec-ch-ua': '"Google Chrome";v="95", "Chromium";v="95", ";Not A Brand";v="99"',
'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/95.0.4638.54 Safari/537.36',
'x-dt-custom-data': 'eyJ1c2VySWQiOiIxMi1hZmRjM2Y5Zjc0OTM4YWE4M2JlMmEzM GE4YzA2MGY3NyIsInNlc3Npb25JZCI6ImV5SmhiR2NpT2lKSVV 6STFOaUlzSW5SNWNDSTZJa3BYVkNKOS5leUp2Y0dWeVlYUnZjb DlwWkNJNk1USXNJbk5sYzNOcGIyNUpaQ0k2SW1GbVpHTXpaamx tTFRjME9UTXRPR0ZoT0MwelltVXlMV0V6TUdFNFl6QTJNR1kzT npFMk16a3pNakV3TURraUxDSjBhVzFsYzNSaGJYQWlPakUyTXp rek1qRXdNRGtzSW5WelpYSkpaQ0k2SWpFeUxXRm1aR016Wmpsb U56UTVNemhoWVRnelltVXlZVE13WVRoak1EWXdaamMzSW4wLmk 5dzdYZlZZYWVwTmQyU2t4YWZhRVZRSXJSOXcxbHBxRXJ5WEFld TJjaU0iLCJtZXJjaGFudCI6InFuZXQifQ==',
'accept': '/',
'origin': 'https://vieon.vn',
'sec-fetch-site': 'same-site',
'sec-fetch-mode': 'cors',
'sec-fetch-dest': 'empty',
'referer': 'https://vieon.vn/',
'accept-language': 'en-US,en;q=0.9,vi;q=0.8',
params = (
('platform', 'BROWSER'),
('type', 'MOVIE'),
# params inserted below will be passed to data-raw
token = 'U2hHTmdoTlOWPoaCIYRMfeFuqPTnaiNhpVp6GStkEV6naRp3L 48Aq5SYSdgFdbIT9YzNmvAou5NQYVbSxfZWsSfKR0H-cVJN4goW0N05mu11a-A_ErwbLhuuy4csT-DUjCPRF2G0JUs0VcUhRP5bgJ3ta6M7TZUT'
provider = 'kakaotv'
requestid='5270822'
releasePid = "_qVpiY31v_oU"
# response = requests.post('https://widevine-proxy.ott.yandex.ru/proxy', headers=headers, cookies=cookies, data=data)
# print(f'{chr(10)}widevine_license: {response.content}')
#NB. Original query string below. It seems impossible to parse and
#reproduce query strings 100% accurately so the one below is given
#in case the reproduced version is not "correct".
# response = requests.options('https://api.ott.kinopoisk.ru/v12/license-affected-content-metadata?contentIds=4b63db58ab27e92b90a457e533b000 07&serviceId=25', headers=headers)
# dash-cenc/hdr10_uhd_hevc_ec3.mpd
# https://strm.yandex.ru/vh-ottenc-converted/vod-content/4315082489d87677b21f7c83593fcb7...d_hevc_ec3.mpd
# 'GET /certificate HTTP/1.1'Last edited by Dannyboi; 29th Dec 2021 at 19:15.
So you are using an mpd like… https://blablabla.mpd_1080p ? What app are you using to download?
As for those headers… there are two separate sets of headers there
I give up, OP now wants, and I quote,
Even though I've mentioned I don't use a script, Here's yt-dlp, mp4decrypt and ffmpeg. start learning.yer thanks can u send me your working script plz
And again I'm asked, can I have a working web-dl script.
Christ, tell you what, why don't I just download everything for you and post it on a torrent site for you to use. or some 2000's DDL site.
That's me off the internet for a few days. Beggars, beggers beggars and one claims he wanted to learn l3 dumping. Well, that changed quickly.
1. Prime Video usually doesn't allow to dump L3 CDM using this method, so you should use another app or website.
2. Before running dump_keys.py on your PC, open the app/website on your Android device (without running the video). Then run dump_keys.py on your PC, and when you're at "Hooks completed" step, press Play on your app/website to run the DRM protected video.
3. If everything goes well, the keys should be dumped.
I managed to dump several L3 CDMs from one device, for example by running a test video on https://bitmovin.com/demos/drm (in Chrome, installed from GooglePlay store on the android device)
Ahhh, i get ya. Wonder if fixing the ua string would stop that, shame Chrome on android removed that function ten years back, or so. But i think bromitewebview might allow changing UA string see https://forum.xda-developers.com/t/magisk-module-webview-manager.3936964/
did you tried to install this android version on it https://forum.xda-developers.com/t/rom-gt-p52xx-unofficial-7-1-2-lineageos-14-1.3587761/
it says that
Code:What's working RIL (audio calls, data, sms, mms) 2D/3D acceleration HW video encoding/decoding Screen cast (Miracast/Wifi Display) MHL/HDMI Sound InfraRed Camera Wifi Bluetooth GPS Sensors SDCard, USB OTG Tethering (USB, Bluetooth, Wifi) Software DRM (Level 3, see below)
How to use working CDM to decrypt L1 content
By mathieuthibault in forum Video Streaming DownloadingReplies: 15Last Post: 21st Oct 2023, 08:41 -
Widevine CDM
By KyoGo in forum Video Streaming DownloadingReplies: 8Last Post: 19th Jul 2023, 04:43 -
new cdm
By ThunderRanger in forum Video Streaming DownloadingReplies: 0Last Post: 6th May 2020, 04:16 -
Android Players vs LavFilters-MadVR? Looking to go to Android BOX
By therock003 in forum Software PlayingReplies: 3Last Post: 20th Jul 2018, 12:11 -
Android:i want to play this channel in vlc android application (vlc.apk)
By sam jack in forum Newbie / General discussionsReplies: 5Last Post: 16th Oct 2017, 17:10
