VCR was working well.
I was using it to convert old VHS-C tapes to mp4.
Then it stopped working.
When I press Play, the tape advances normally inside the VCR, but the counter / timer doesn't advance and the video is a black screen.
If I fastforward, I get video for a couple seconds but then the screen goes dark again.
Have tried other VHS tapes and the same problem now exists for all tapes.
Have tried FF/RW a few times which hasn't helped.
Have tried cleaning the heads with 99% isopropyl alcohol which hasn't helped.
Thoughts?
I'm not expert, but you only don't see video? Do you hear any audio? You use grabber or something like that?
What if You just connect VCR to TV?
Maybe device You are using to capture is broken?
If no, it could be also damaged cable (try another cable)
Or damaged output in VCR.
For example I have VCR with broken timer screen but it's playing good. -
Troubleshooting HDR playback on TV
By davexnet in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2020, 16:55 -
Troubleshooting transfer of VHS tapes to digital
By Kajaboss in forum MacReplies: 10Last Post: 19th May 2020, 15:37 -
iMovie 10.1.11 troubleshooting
By Kajaboss in forum MacReplies: 1Last Post: 10th Apr 2020, 16:53 -
Panasonic DMR-EZ48V DVD/VCR VHS Combi - Transfer quality question
By vcogent in forum Newbie / General discussionsReplies: 3Last Post: 6th May 2017, 09:03 -
Troubleshooting PSU and PC Shutdown
By beavereater in forum ComputerReplies: 17Last Post: 11th Feb 2017, 11:01
