  1. Hello!
    I have a 210p HEVC HDR Dolby Vision video file that I want to play on my SDR 1440p display. But for some reason it shows weird colors, lots of green and shades of purple:
    [Attachment 62576 - Click to enlarge]
    I have searched for hours now, and have tried:
    - MPC-HC with MPC Video Renderer, no luck
    - MPC-HC with madVR, no luck
    - MPC-BE with Enhanced Video Renderer, no luck
    - MPC-BE with MPC Video Renderer, no luck
    - MPC-BE with madVR, no luck
    - VLC 3.x with OpenGL for windows
    I understand that tone mapping should take place, but I can't seem to get it to work.
    For MPC Video Renderer I had set it to convert to SDR, doesn't help.
    Same for madVR: I tried to set up calibration with bt.709 or bt.2020 gamuts or leaving it disabled, combined with "tone map HDR using pixel shaders" option or "let madVR decide".
    No matter what I do, I cannot get it to work.
    What options do I have?
    Thanks!
    Aug 2006
    If only Dolby Vision is present, then there is currently no way to watch it on an SDR display and see the correct colors. Dolby Vision is a proprietary technology that uses dynamic HDR metadata and there is no software decoder available, so the display itself must have the ability to decode and display it.
    You need a video that uses HDR10 or HLG to watch HDR content on an SDR display, plus a software player that supports the type of HDR being used. HLG and HDR10 are open-source technologies and use static HDR metadata. PC software players use tone-mapping to approximate HDR color on an SDR display using look-up tables (LUTs) or an algorithm to perform the conversion.
  3. Thanks! Yeah, that's what I actually managed to find in about 5 minutes after posting the question... ah rubber duck debugging.
    Dec 2021
    United Kingdom (Scotland)
    It appears we both have the same problem. For me, this only happens sometimes, but not always, when I try to play video files saved on my laptop that are 2160p or above.
    I have Lenovo Y700 4K laptop so I guess that is disappointing. So, was there some kind of solution? I am a full on noob so can't figure out myself what to do.
    Also, any idea how to tell if a video file will give me this problem or now? So I know what files to avoid. thanks.
