Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 71
  1. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    It's more complicated to learn Avisynth, but at least it works. If you say that Subrip "works" then InpaintDelogo results would be like magic to you.
  2. Originally Posted by VoodooFX View Post
    Not sure. It seems your explaining things to the other guy shows how complicated it seems. Then you say Avisynth is complicated lol It seems like even before I try it, it will be too hard. You keep telling people to learn.. study or read Avisynth? That's not good for beginners.
    I just wanted a fairly, simple experience and not keep asking a millions questions and VideoSubFinder with it faults is just better imo
    But who knows, I have to try yours to truly see. But if it takes a lot of processing power, coding or line command knowledge than VSF is the best option for me lol
    Even today I was able to pull some subs not bad. Using gImagereader not ABBY Fine Reader. Now I'll just check my subs and timing and be done.
    It seems the other guy gave up. Can't say I blame him hahaha
  3. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    OP asked about how to use InpaintDelogo, not whatever you imagine here. Strangely you keep insisting on VST when OP wrote already that its results are not good for him.
    If SubRip, VST, Tesseract results are good for you then use them, no one is forcing you to use anything else. Thanks for sharing your "few days" experience.
  4. Originally Posted by VoodooFX View Post
    Not sure why you're getting mad, but if VSF is easier, why do you insist yours is better? I noticed you was getting impatient with the OP, maybe you should create a better user guide or perhaps, a guide showing possible mistakes and solutions to the problems? Why would you get upset if people ask questions and then want people to try your software?
  5. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    But if it's white, why do you insist that is square? I noticed I should do things, perhaps I need to do more things I don't know about, please let me know.
  6. Originally Posted by VoodooFX View Post
    I will let you know... but the OP probably gave you some good idea that could help noobs/newbies to make things easier to understand. Jagabo was really helpful and trying. Whoever that person is. I appreciate his/her patience. But... maybe you was having a bad day, I don't know. Has Baldrick tried your software? He might be able to help as well.
  7. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    That was rhetorical sarcasm to your clueless nonsense. Hilarious that you are trying to answer it.
  8. Now I remember, you're the one who keeps getting upset that the app isn't that great like VideoSubFinder and keep trying to disparage VSF. And have very little patience with people trying to use your app. If you're still this upset after a month... wow lol
  9. Piggybacking in this old thread: I'm a bit at loss on how to use InpaintDelogo, any advise will be helpful:
    I have a video that uses 5 different colours for subtitle. Will I need to create 5 masks manually, or can I use a DyMask/DynTyne to extract all the subtitles?
    I have measured pixel info for the subtitle colours and the colour ranges are:
    Range 1, HEX= [BA9C80 BB9881 BC9A82 BD9A83 BD9B82 BE9982]
    Range 2, HEX= [C59591 C5959D C5959D C59690 C5969C C59792 C59890 C59892]
    Range 3, HEX= [C69492 C6959C C6979D C6979D C6989D ]
    Range 4, HEX= [D18E51 D18E52 D18E53 D18F53 D19053 ]
    Range 5, HEX= [D78364 D78364 D88264 D88364 D88366]
    But I do not know how to apply these pixel info correctly. I tried DynMask5/DynColor but it still misses many subs. DynMask2+DynTune does a good job for couple of colour ranges but misses out the rest. I guess I should do colour by colour in steps, but I do not know how. Any pointers / tips would be helpful
  10. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    Is that for karaoke subs? They are not very suitable for extraction, anyway, cut video sample of them.
    EDIT:
    You don't need to add different shades for one color, there is color tolerance parameter.
    There is support for multiple colors at once, but I never tried it.
  11. Originally Posted by VoodooFX View Post
    EDIT:
    Thanks for the quick reply. Here is a cropped sample clip:
    https://mega.nz/file/C18iUQ4L#Z3318cpCGHj1T9x1eQsSADvL8Lch_mp6KcfdlZtpVcg
  12. Originally Posted by VoodooFX View Post
    Don't try to learn on SD videos. Currently, the script on SD doesn't work as expected, so you wouldn't understand what is going on if something goes wrong there.
    I've given this a long pause, partially because I ONLY had SD content to extract subs from. But I finally have a good HD case.
    I still have a script error: "There is no function with the name 'InpaintDelogo'."
    It happens when I try to run a text file (avs extension) with this content: InpaintDelogo(Loc="100,400,-100,-60", Show=4, DynMask=4, DynTune=160, DynMask4H=70) SubsMask2Img(ImgDir="")
    The plugin is there, though, in: C:\Program Files\AviSynth+\plugins64\InpaintDelogo-main
    Maybe I skipped a step somewhere?
    SubsMask2Img() extracts images from a black/white mask video. So you need to get mask video first.
    If you don't know how get masks from subs then InpaintDelogo has few methods for you (read about "DynMask" parameter).
    Question 2. I recognise the 'mask' from delogo efforts, but do you need a mask if you want to extract the hardcoded subtitles too?
    Any advice that helps me forward is appreciated!
    This is nøt å signåture.™
  13. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    Put it in plugins64, not in "InpaintDelogo-main".
    Yes you need to create a dynamic mask, that's not related to the "mask" parameter.
  14. Ah, thanks, so the plugin was one folder to deep. (Side note: It's not important here, but won't there be file name conflicts inside the plugins64 folder then? Especially with the usual 'license' and 'readme'.)
    Anyway, I'm not quite there yet - now I get "Script error: Invalid arguments to function 'InpaintDelogo'." (Line 1). Line 1 was, as before, "InpaintDelogo(Loc="100,400,-100,-60", Show=4, DynMask=4, DynTune=160, DynMask4H=70) SubsMask2Img(ImgDir="")" but I'm probably skipping a step?
  15. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    ...won't there be file name conflicts inside the plugins64 folder then? Especially with the usual 'license' and 'readme'.
    What conflicts? Those mentioned files are not plugins so no need to put them there.
    Looks like you didn't input any video.
    And remove SubsMask2Img as it's for the extraction, first you need to get a proper mask.
  16. Right, thanks again, and actually that makes more sense than what I had supposed.
    So, using some old movie I found on archive.org, should it look like this?
    AVISource("C:\[path]\Hypocrites1915.mp4")
    Unfortunately, it says: "AVIFileSource: Couldn't open file 'C:\[path]\Hypocrites1915.mp4'."
  17. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    Don't use AVIFileSource() nor DirectShowSource(), those are outdated filters.
    Use LSMASHSource:
    LWLibavVideoSource("c:\Hypocrites1915.mp4)
  18. Originally Posted by VoodooFX View Post
    Use LSMASHSource:
    EDIT: OK that command gets me further!
    But because I'm at a fresh PC (compared to the start of the thread), I need to add some of the other plugins again, for example I got an error message that GRunT is missing.
    Basic question now, but... I can go here and download the zip: https://github.com/pinterf/GRunT
    But then what? Where precisely do I put which of those files?
  19. (Specifically because there doesn't seem to be a .dll file in that download, so I'm in the dark how to add that as a plugin - thanks again!)
  20. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    I guess you are downloading the source code instead of the compiled plugin, look at "Releases" there.
  21. Aha, thank you, so I did! Now I get further, or at least I get up to the point of "Crop: Destination height is 0 or less".
    And the process creates an .lwi file each time (in the example: Hypocrites1915.mp4.lwi), even when it's got errors. Is that a kind of temporary result? (I always delete them afterwards.)
  22. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    Probably Loc is wrong.
    Read the help/manual (at the top of InpaintDelogo.avsi) about parameters.
    It's the index file created by LSMASHSource.
  23. Pixels starting from the top down? So for this simple 480x360 example, with title cards, I chose Loc="60,80,360,180".
    The next hurdle is "Script error: There is no function named 'DistanceFunction'." As before, I'm grateful for advice!!
  24. Yes, it turns out that was the same error as with GRunT...
    In that case, "no function RemoveGrain" probably is to do with another missing plugin?
  25. Yes, but which one! However, I can check them all just to make sure.
    Brings me to a side question - https://github.com/pinterf/TIVTC/releases/tag/v1.0.29, do we also need TDEINT?
  26. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    Yes, but which one!
    All.
    ...do we also need TDEINT?
    No.
  27. So that's all done. The video now starts playing, except that it looks like it's 2 bit quality. (Probably supposed to.)
    Is the following correct?
    I can also just use VLC? And I just need to let the entire video playback at its own speed?
    I don't see any images yet; if I don't specify a directory, will it just put them in the same place as the video file?
