Hi, I have these Madman dbz dvd episodes that I would like to convert back to the original ntsc framerate and resolution cause they were converted to 25fps and have blended frames as a result, there is no speed change for the audio as far as I am aware. I am a bit of a noob with video encoding so forgive my relative lack of knowledge on this. I attached two examples that I cut out losslessly with avidemux that show the problem and also the mediainfo file of the full video file in case it helps in any way. Thanks!
This will be less destructive to anime details and lines.
Code:QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, tr1=2, tr2=1, NoiseTR=2, sharpness=0.1) srestore(frate=23.976)
Blended Frames during QTGMC - 25fps assuming bad authoring to PAL format?
By LaserBones in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2020, 07:33 -
NTSC blended from a PAL source, wobbly after srestore
By bruno321 in forum RestorationReplies: 16Last Post: 28th Oct 2018, 13:29 -
NTSC blended from a PAL source, can't restore it properly
By bruno321 in forum RestorationReplies: 5Last Post: 6th Oct 2018, 11:42 -
How to remove blended frames from NTSC 29.976?
By midts in forum Video ConversionReplies: 2Last Post: 15th Aug 2018, 13:07 -
PAL to NTSC with avisynth - blended frames
By nesburf in forum Video ConversionReplies: 7Last Post: 28th Dec 2017, 00:21
