Hi, I have three queries related to combining two videos of different aspect ratio, resolution and bitrate.
Is there a tutorial or any resource on how to merge open matte and a 4k video?
Presently the 4k video has black bars at the top and bottom, so basically I would like replace those with information on the top and bottom of the frame from the 1080p open matte video.
Is it possible to preserve HDR information from the 16:9 4K video also?
It appears the two video files are the same length and framerate so I'm hoping syncing should be no issue, however the bitrate is also considerably different, would downscaling the 4k to 1080p be a better option to keep a consistent quality of video with the open matte 1080p?
An ideal solution, if possible, would be to have the video in 4k HDR and full screen.
For reference, here are the media infos of the 4k and 1080p videos:
4K:
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 21 min
Bit rate : 59.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.300
Stream size : 59.1 GiB (93%)
Writing library : ATEME Titan File 3.8.3 (4.8.3.0)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1838 cd/m2
Maximum Frame-Average Light Level : 277 cd/m2
1080p open-matte:
Format : AVC
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 11.9 Mb/s
Maximum bit rate : 15.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.239
Stream size : 11.8 GiB (95%)
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Any help would be much appreciated![]()
Results 1 to 1 of 1
Any solution to transform HDR video to Youtube compatible HDR?
By Truthler in forum Video ConversionReplies: 2Last Post: 20th Jul 2021, 12:37 -
What is the best way to resize 4k HDR -> 1080p HDR? Are there gotchas?
By Msuix in forum Video ConversionReplies: 2Last Post: 1st Mar 2021, 03:58 -
Open Matte and Widescreen - Each different
By alesad2003 in forum EditingReplies: 0Last Post: 26th Feb 2021, 12:15 -
Combined MP4's into a 17-hour video, but video player says it's 13 hours
By Hypersonic1 in forum Video ConversionReplies: 22Last Post: 25th Mar 2018, 04:41 -
PS4Pro Resident Evil HDR game only showing in 1080p
By enigami in forum Newbie / General discussionsReplies: 2Last Post: 1st Mar 2018, 15:02
