  1. I am evaluating a bunch of different apps including VidCoder, WINX HD converter, Handbrake, and a few others.
    What I want is:
    - Encode to H.265 (for size/space reasons)
    - Remove all but the forced english (if it exists) subtitles to simplify the video
    - Begin encoding by way of command line to automate encoding
    - Use hardware acceleration where possible to speed up encoding.
    I know a lot of this has been discussed but I cannot find a discernable real suggestion so I am asking outright if anyone has a software application they recommend for the above. So far VidCoder is winning except for the speed requirement. It is very slow.
    Thanks!!
  2. For command line encoding try ffmpeg. A sample drag/drop batch file for converting to 10 bit hevc using Intel QSV:
    ffmpeg -y -benchmark -hwaccel dxva2 -init_hw_device qsv=hw -filter_hw_device hw -v verbose ^
        -i %1 -pix_fmt p010le ^
        -vf "hqdn3d=1.0:1.0:1.0:1.0" ^
        -load_plugin hevc_hw -c:v hevc_qsv -preset:v slow -global_quality 18 -g 50 ^
        -profile:v main10 -colorspace bt709 -color_range tv ^
        -acodec copy -map 0 "%~dpn1.hevc10.qsv.mkv"
    Nvidia and AMD hardware encoders are supported too.
