Page 3 of 3
FirstFirst 1 2 3
Results 61 to 88 of 88
  1. Test on BetacamSP (into DV25) capture: https://imgsli.com/MjYxMTMx https://imgsli.com/MjYxMTQx
    Hmm,.. old QTGMC with some light contrast sharpening?
    64x times slower.
    Leaving the Q in QTGMC,.. going back to TGMC?
    May 2005
    PAL User
    Quadratic, not Quick!
  3. Are you sure? (got a reference for that)
    iirc QTGMC started out as basically TempGaussMC with presets to make it usable,...
    "(Quick) Temp Gauss Motion Compensated" and thus the Q was quick ('quick' also was then also kind of funny, since it was still horribly slow)
    + I don't see where the quadratic would come from.
    seems I'm not the only one who thinks this is correct:
    https://forum.doom9.org/showthread.php?p=1987389#post1987389
    May 2005
    PAL User
    Don't believe everything you see on the Internet. I don't know what to believe!
    https://www.quora.com/unanswered/What-is-QTGMC-and-how-can-I-use-it-to-deinterlace-my-...ideo%20footage.
    If it does stand for "Quick", that's an odd interpretation of "quick", even without this 64x slowdown.
  5. Like I wrote, the quick more came from its quicker than TMGMC and yes, it was kind of a funny thing back then.
    => Quora is wrong.
    May 2005
    PAL User
  7. Originally Posted by dellsam34 View Post
    How would someone use this instead of the old one? Just install it and it would remove the old QTGMC?
    Unpack archive to some folder and add your processing script (I typically call it src.avs) and Import("M_QTGMC.avsi"):
    Example:
    LoadPlugin("ffms2.dll")
    Import("QTGMC.avsi")
    FFmpegSource2("aos_xtr.avi")
    ConvertToYV12(interlaced=true)
    AssumeBFF()
    old_slow=QTGMC(preset="slow").Subtitle("old slow")
    new=M_QTGMC().Subtitle("M_QTGMC")
    Interleave(old_slow, new)
    Prefetch(2)
    "Any video samples comparing the two?"
    It was over-night quick release. At my home E7500 CPU it runs at 0.17 fps with SD so I will make some movie demos at next day at work (at least i5-9600K expected to run about 10x faster).
  8. Originally Posted by Selur View Post
    64x times slower.
    Oh - if Q was Quick - so it is M_USTGMC of Monster-UltraSlowTGMC. (Where Monster is a new mascot for mvtools 2.8.x series design pre-released in 2024 as golden-furred Dimar Dragon https://www.furaffinity.net/view/56366839/ with lots of small details painted but also in same pre-release alpha state with temporal mane). I will replace my mascot image on github soon for a new Monster headshot
    Really M_ may be as Many-*TGMC as M_QTGMC is only wrapper for several calls to QTGMC with different params sets and gathering details from each result. It can be also used with 'classic' QTGMC based on classic 2.7.x mvtools (pinterf release update to 2.7.46 in May 2024 https://github.com/pinterf/mvtools/releases/tag/2.7.46 ). Simply remove all new params in QTGMC calls (named mvt_*).
    "since it was still horribly slow"
    I understand 64x times slower it is big enough performance penalty. But it is expected for usage as 'industrial grade deinterlacer' (we use it for State broadcasting) so can run on CPUs like FranceBB's Xeons 56c/112th not very slow. For denoise our department currently like Topaz VEAI but it only accepts progressive and we have large interlaced BetacamSP and later archive.
    Also not about MT and quality: Internal intra-frame MT (via AVSTP.dll) can make H-striping artifacts because each H-stripe processed in MAnalyse as complete frame so edge of frame border predictors are limited in quality. Also I not sure but overlapped blocks may not cover seams between H-stiped too. So for max quality only frame-based MT via AVS+ is recommended. I not use avstp.dll so it is batter to add mt=false to mvtools in QTGMC to be sure.
    As I see mt for mvtools is controlled via
    bomt = sh_GetUserGlobalIMTbool() somehow.
    Also this 64x slower is not the only new possible mode - it is only sort of 'medium' performance/quality balance. The AreaMode of 1 with AMflags=1 is only +4 new search positions for each block while 16 and more positions possible even for small 8x8 block size. Offsets expected to be effective to blksize/2=4 for 8x8 and currently only offset of 2 used of 1,2,3,4 possible with 4 or 8 search positions with each offset, so max AreaMode load is +32 search positions for 8x8 and much more for 16x16 block size. It is about 32/4=8x slower. Though 16x16 block size is more stable and require less refining.
    I think to make also some 'lighter' modes like pel=2 and no AreaMode for 16x16 blocks - it expected about 10x faster but quality may be visibly lower.
    Update: With i5-9600K CPU it is not so slow - only about 6x times slower in comparison with QTGMC(preset="slow") with x264 running with preset=slow for h.264 transcoding. 7.5 fps with M_QTGMC and 45 fps with QTGMC.
  9. Originally Posted by dellsam34 View Post
    Here is DV25 captured BetacamSP old recording https://drive.google.com/file/d/1Pc7vzWNc6KH_uX2zVTyaa0gxQSEJxK5l/view?usp=sharing . It has some weird chroma plane H-jumping (at some objects only ? and at one field) and I am not sure where it comes from. Maybe some defect of capturing.
    Here is 2x upsized with SincLin2Resize (to show small details better on computer screens not supporting such long sinc kernels resize) processed with M_QTGMC - https://drive.google.com/file/d/1WBXDyDSrUHF2EVGvrghgGZ8qIAfXebvz/view?usp=sharing .
    Most difference with QTGMC(preset="slow") is at fine details at fast moving objects.
    All other versions with old/classic QTGMC or other deinterlacers anyone can create from source locally.
  10. Capturing Memories dellsam34's Avatar
    Jan 2016
    Thanks for the samples, I'm finding hard to see the difference without side by side comparison, but I think the slow speed of it is a deal breaker for me.
  11. "without side by side comparison,"
    You can run your typical workflow with QTGMC and use StackHorizontal() in AVS. I think of creating left-right old-new versions encode but I think users like to see full-screen run of a moving pictures sample and to estimate overal quality. The same is for industry experts quality evaluation - no side by side or frame interleaved comparisons (?). I tried to compare also with realtime hardware deinterlacing via NVIDIA Pascal-series card (via MPC_HC) - it looks much less detailed. But I think still some sharpnener is active in QTGMC with slow preset by default (?).
    Apr 2024
    Mediterranean
    [Attachment 85092 - Click to enlarge]
    Another "negative" of nnedi3 alone - it's not motion adaptive. It "blindly" processes everything. So in no motion scenes - where the image is actually progressive content - nnedi3 will degrade it (because it's a single field, not weaved 2 fields for full quality) . yadifmod2+nnedi3 will only slightly degrade it (yadifmod/yadifmod2 omit top and bottom rows, such as QTGMC border=false). QTGMC will be better (depending on the settings used), but bwdif should be almost perfect if it registers no motion
    That was the reason for that "pause" at the beginning in the gif demo. Those first few frames have no motion. A perfect deinterlacer will weave() the 2 field to produce full quality image. QTGMC comes close, but very slightly degrades because of the additional processing . yadifmod+nnedi3 misses the top and bottom row (so does QTGMC default without border=true). Bwdif+nnedi3 is essentially perfect for the static sections, if it detects no motion correctly
    But in motion, all of them will generally have more flickering artifacts more than QTGMC
    bwdif + nnedi3 as edeint is generally better than yadifmod/yadifmod2 + nnedi3 as edeint . Bwdif alone is actually faster than yadif alone on most semi recent computers (with SSE2 and AVX) and produces higher quality - yadif and yadifmod are basically obsolete IMO, they can be safely replaced with bwdif for faster and higher qualtiy filtering
    Of course, YMMV - different types of sources, scenes, content might react better to different deinterlacing algorithms.
    (my bold)
    case in point: i think no matter what you do you can't make those subtitles' edges look sharp in QTGMC.
    via
    clip = havsfunc.QTGMC(Input=clip, TR0=2, TR1=2, TR2=1, Rep0=1, Rep1=0, Rep2=4, DCT=5, ThSCD1=300, ThSCD2=110, SourceMatch=3, Lossless=2, Sharpness=0.1, Sbb=0, MatchPreset="slow", NoiseProcess=2, GrainRestore=0.0, NoiseRestore=0.4, NoisePreset="slow",StabilizeNoise=false, NoiseTR=0, NoiseDeint="bob")
    (stolen from hybrid script and this post
    https://forum.selur.net/thread-3429-post-19638.html#pid19638 seems a bit better than "placebo")
    while bwdiff nails it, without nnedi3 for edeint, also in hybrid (vapoursynth).
    mpeg2 source
    https://www.mediafire.com/file/uo7qd5jftr8rryx/vhs_ba3_vhsi_NEW_LSF_trimmed.mpg/file
    in image, i'm pointing to jaggy 'K' (in bwdiff image) as something good, because QTGMC "anti-aliased" it, ie it applied EDI for no good reason, it didn't preserve the original. also qtgmc with these settings is still doing some denoising.
    previously in the thread, you discussed quality of tv deinterlacers. it depends on the brand of tv, but i believe sony (was?) best (i guess that's why i have 2 sony tvs), but prior to 2014 bravia3 and "x-reality" processor, sony was also utter garbage for deinterlacing, like other mfrs.
    deint. is one part of the job, upscaling is another, i dunno how well sony does by the time SD image is blown to 4K, but i do know that QTGMC is easilly better than my sony tvs for this:
    https://www.mediafire.com/file/b913kwcu79d5ucr/lacing_credits_0001.mpg/file
    https://www.mediafire.com/file/wi9xifdgnw7mg4h/SAT1.FFS.2011.03.21.mpg/file (didee ripped this from broadcast)
    feel free to test it, play back on tv those files, and anything you may conjure via preffered deinterlacing method of your own.
    you probably won't find a tv that does justice to all 3 files i linked in this post, if you pay attention to both static subtitles in first clip, and motion (artefacts) in latter two.
    i'm pretty sure sony doesn't do EDI, but it has some level of motion adaptivity as there's no "interline twitter" ie 25/30hz flicker (bobbing) at vertical edges that appear on just one field of video, like the subtitles in first clip i linked.
    wouldn't it be interesting if sony just took some (older) avisynth deinterlacer and put it into silicon? hehe....
    i'm investigating all of this to have an option to watch laced video deinterlaced on PC, in real-time, because i didn't bother with it upon archiving video, because that would just be wasting time.
    but also because software playback beats hardware players on all fields, both quality and usability.
    offcourse, PC connected to TV, that way you pick deinterlacer and scaler.....in that case TV is just a big monitor....
Name:	bwdiff vapoursynth 2025-01-25_033410.png
  13. "while bwdiff nails it," have you tried using bwdif in qtgmc?
    Apr 2024
    Mediterranean
    i just see bwdif in the context of 'edimode' here
    http://avisynth.nl/index.php/QTGMC
    in one sentence ("For EdiMode modes "BWDIF+NNEDI3" and "BWDIF+EEDI3"."), and not in following edimode syntax:
    EdiMode (string) Interpolation method, from "NNEDI3", "NNEDI2", "NNEDI", "EEDI3+NNEDI3" (EEDI3 with sclip from NNEDI3), "EEDI3", "EEDI2", "Yadif", "TDeint" or "RepYadif" ("repaired" Yadif), anything else uses "Bob"
    it seems it's havsfunc addition:
    QTGMC 3.33
    EdiMode: Interpolation method, from "NNEDI3", "EEDI3+NNEDI3" (EEDI3 with sclip from NNEDI3), "EEDI3" or "Bwdif", anything else uses "Bob".
    https://github.com/HomeOfVapourSynthEvolution/havsfunc/blob/master/havsfunc/havsfunc.py
    best idea would be bwdif for static portions, and "usual" qtgmc (presets) for motion.
    probably.
    i didn't check bwdif vs. sat1 and lacing_credits clips....
    will check, thanks for suggestion.
  15. Also note that if you are using Hybrid, https://github.com/HomeOfVapourSynthEvolution/havsfunc/blob/master/havsfunc/havsfunc.py isn't the havsfunc version Hybrid used, but https://github.com/Selur/VapoursynthScriptsInHybrid/blob/master/havsfunc.py (those are not identical)
    Cu Selur
  16. Originally Posted by i4004 View Post
    Yes, and people have tried - various approaches use a motion mask with overlay. eg. QTGMC (some settings) for "base" layer, and a weaver like BWDIF / TDeint (tryweave=true) for the static overlay sections
    The problem is creating a "perfect" motion detection mask. Things like small motions, compression artifacts, noise etc... can contaminate detection.
    Newer high end TV's have this issue too ( including newer sets that use "AI" chips). There is often a few fields "glitched" before it "kicks" in
    Another common problem, far worse for QTGMC is lower thirds/ HUD's with lots of motion underneath (e.g. video games, sports content with overlays). QTGMC will often warp and distort a large section around the motion underneath in that scenario. Using a "simple" deinterlacer if often better in that case, because the large distortions are very noticable
    None of the deinterlacers are "perfect" (except for a weaver with 100% full frame, 100% static content), and there are pros/cons to each method
  17. will check, thanks for suggestion.
    btw. while testing: one can also use EdiExt with https://github.com/pifroggi/vs_deepdeinterlace, https://github.com/HolyWu/vs-mfdin or any other deinterlacer,..
    Cu Selur
  18. Member
    Apr 2024
    Mediterranean
    AI talk just reminds me of sony advertising blurb where they claimed video is checked against (huge) database and adjusted accordingly.
    of course, those tvs look best when you turn off any processing setting you can, and the main difference between sony of that era and others sets was sony actually let you turn those things off completely (noise reductions etc.), while with other mfrs you always saw they're still doing it, even if you turn off those functions....
    ai is next best thing (same as nanotubes or fuzzy logic some time ago) that will soon become history. it's a good yt clickbait, "AI upscaled".
    as for testing, yes
    clip = havsfunc.QTGMC(Input=clip, TR0=2, TR1=2, TR2=1, Rep0=1, Rep1=0, Rep2=4, DCT=5, ThSCD1=300, ThSCD2=110, SourceMatch=3, Lossless=2, Sharpness=0.1, Sbb=0, MatchPreset="slow", NoiseProcess=2, GrainRestore=0.0, NoiseRestore=0.4, NoisePreset="slow",StabilizeNoise=False, NoiseTR=0, NoiseDeint="bob", EdiMode="Bwdif")
    produces result even a bit sharper than mere bwdif.
    pot-player's 2 frame adaptive deint. mode also doesn't seem to be graphic-destructive as qtgmc with nnedi.
    let me just quickly check what these sony x-reality pro(!!!) tvs are doing with "vhs_ba3_vhsi_NEW_LSF_trimmed.mpg/file":
    interestingly, the older model shimmers few frames around scene-change (easilly visible on tv station's logo HRT2), but the new one doesn't. both advertised as x-reality pro.
    both are preserving static graphics very well.
    i'll probably compare the artefacts of pot player 2 frame, bwdif and sony tv deinterlacers next.
Name:	x-reality 2025-01-26_033056.png
  19. What could be your comments on GPT4.5 comment on this script?:
    If processing time is not a concern and your goal is maximum achievable quality, detail preservation, and effective noise handling, here's my carefully-tuned recommendation:
    Advanced QTGMC Configuration (Highest Quality, Slow Processing)
    avisynth
    QTGMC(TR0=2, TR1=2, TR2=3, Rep0=1, Rep1=1, Rep2=4,
    \ DCT=5, ThSCD1=240, ThSCD2=100,
    \ SourceMatch=3, Lossless=2, Sharpness=0.2, Sbb=1, MatchPreset="very slow",
    \ NoiseProcess=2, GrainRestore=0.2, NoiseRestore=0.4, NoisePreset="slow",
    \ StabilizeNoise=true, NoiseTR=2, NoiseDeint="bob")
    Rationale for These Maximum-Quality Settings:
    Temporal Radius (TR): Increased (TR2=3) for maximum accuracy and detail consistency across frames.
    Repair (Rep) Modes: High-level repair (Rep2=4) ensures aggressive artifact correction at the cost of processing speed.
    Source Matching (SourceMatch=3) and Lossless (Lossless=2): Highest setting for maximum detail retention.
    DCT (DCT=5): Maximum frequency-domain accuracy for precise processing.
    Scene Detection Thresholds: Slightly reduced (ThSCD1=240, ThSCD2=100) for improved scene-change detection accuracy.
    Noise and Grain Restoration: GrainRestore=0.2, NoiseRestore=0.4, and temporal noise radius (NoiseTR=2) maintain natural textures while controlling noise effectively.
    Sharpness Increased (0.2): Subtle, noticeable sharpening enhancement.
    StabilizeNoise and Borders (Sbb=1) Enabled: Ensures stable noise patterns and clean frame edges.
    This script is optimized solely for achieving the highest possible visual quality and accuracy, disregarding processing time entirely.
    Apr 2024
    Mediterranean
    my comment is that chatgpt just found some discussions on selur's or doom9 or this forum...heh....
    my suggestion is bwdif for stuff with lots of static shots and/or graphics, and qtgmc for the rest: for example camcorder laced footage has no graphics and it's usually rather non-station, not to say "pretty shaky"
    as for noise, nothing, preserve it or do some mild denoising, mdegrain2 or 3 from mvtools....
    to reply to myself:
    not much difference here, sony obviously used some variation of bwdif or something simillar. but new sony tv looks a bit better than old one. less flicker, less jaggy etc.
    interesting part is handling of inputs: scart input on older sony tv is crap.
    hdmi inputs on both are visibly worse than playback from flash usb stick.
    it doesn't matter what you're inputting to tv, 576i or 1080i, it looks bad.
    so that's interesting: it's either that the device i'm playing it back from is crappy (cheap dvb-t2 tuner) or tv has two separate paths for processing, one for inputs (scart, hdmi), another for local media playback and its internal tv-tuner. ie not the same scaler and deinterlacer is used in both cases.
    or, in other words, they can't do good processing on uncompressed video. because both scart input and hdmi will be uncompressed.
  21. Originally Posted by Skiller View Post
    I myself do not like QTGMC much – at default settings.
    I spent... I don't know... years tweaking and refining it to find settings that make it close to transparent for my sources. And I pretty much suceeded.
    You said if you make QTGMC keep the grain, the grain looks too fine and artificial. I had this problem as well. The key setting here is NoiseDeint="bob". And there are more which may not even seem like they are (as a side effect) related to noise (especially the TR and Rep settings).
    The reason QTGMC is so "destructive" is due to the way the core works. It basically works like this: first it does a dumb bob-deinterlace (with or without more intelligent spatial interpolation such as NNEDI), then temporally blurs the differences in bob-shimmer away and uses motion compensation to detect where to do that and where not to avoid a motion blur effect. That was the original concept written by Didée and named TempGaussMC. It's a bob-shimmer remover. As you can imagine, the side effect of this approach is rather strong denoising. But luckily the script evolved dramatically over the years and allows for the side effects to be compensated – although not too many peoply seem to be offended by those.
    Here is my honest recommendation of settings for keeping grain and making the deinterlacing quite transparent to my eyes.
    Even if you are happy with NNEDI3 alone now, I would like to hear your thoughts on these settings.
    QTGMC(TR0=2, TR1=2, TR2=1, Rep0=1, Rep1=0, Rep2=4,
    \ DCT=5, ThSCD1=300, ThSCD2=110,
    \ SourceMatch=3, Lossless=2, Sharpness=0.1, Sbb=0, MatchPreset="slow",
    \ NoiseProcess=2, GrainRestore=0.0, NoiseRestore=0.4, NoisePreset="slow",
    \ StabilizeNoise=false, NoiseTR=0, NoiseDeint="bob")
    Here my results with my Hi8 XR video wich i captured with a Digital 8 camera to my PC and using Staxrip program, i compare the videos, the left is your code and the right is with the default settings that Staxrip applies:
    [Attachment 87069 - Click to enlarge]
    [Attachment 87070 - Click to enlarge]
    Edit: Now i'm not too sure about this comparison, in the left picture where I used the custom settings of Skiller there is obviously slightly more grain and noise but in the first 2 pictures above, the right one with the blue screen the letters and numbers from the camera's UI are "cleaner" with the edges sharper...
  22. Video Restorer lordsmurf's Avatar
    This is one of those weird rabbit holes.
    A stupid assertion was made (from an OP that hit-and-run posted this years ago), and few/none have ever defended it (and rightly so). It reads like an amateur ad: "Why are people still drinking Coca-Cola? (Drink Pepsi instead!)"
    However, some are giving it "devil's advocate" treatment. And yet, they don't see the forest through the trees.
    - On one hand, most people are (sadly) butchering video with junk hardware, junk software, and Youtube.
    - On the other hand, you have some people seeking better quality deinterlacing, and that should land at QTGMC. This thread isn't helping those folks.
    - On the 3rd weird inhuman hand, you get this thread.
    I think most of us have our favorite custom settings for QTGMC, and I have settings for scenarios. But I still largely default to the presets of Faster, Medium, and Slower.
  23. Originally Posted by lordsmurf View Post
    I think most of us have our favorite custom settings for QTGMC, ....
    Agree. And there is still the option NOT to deinterlace unless there is a good (technical) reason to do so, like vertical resizing. The TV/player deinterlacers may do a nearly equivalent or visually more pleasing job than some borked QTGMC tweaks with its nearly 100 parameters
  24. Originally Posted by i4004 View Post
    as for testing, yes
    I'm testing my definitive QTGMC custom settings in Hybrid to use it for everything from now until something better comes out in the next years/decades (AI or not idk) and I think I will stay with these settings.
    [Attachment 91492 - Click to enlarge]
    I don't like the results using Bwdif in EdiMode so i'm testing others such as NNEDI3, EEDI3 and that combination of EEDI3+NNEDI3 in EdiMode, I don't know if you tested more of these, some people can live with some artifacts and aliasing, others not so at this point is personal preferences for every person I guess.
    I usually combine this with the MC Temporal Denoise filter at very low or low presets for a slightly denoising and the CAS filter at 0,020, I really like the sharpness of CAS at this value of 0,020.
    Edit: Okay i'm doing more tests and using Bwdif in EdiMode is a lot sharper and retains a lot better the edges of the letters and numbers from the camera's UI but also gives more aliasing artifacts and other artifacts, I found my perfect combination that's almost as sharp as Bwdif which is Edimode="Yadifmod+NNEDI3" and I love the results, superb quality and with a proper upscale using NNEDI3_rpow2 with Spline64 and the resize to 1920x1440 with "Bicubic Spline" the quality is incredible for a Hi8 TRV95E analog camera from 98'.
  25. One more experimental update of the ME in mvtools - https://github.com/DTL2020/mvtools/releases/tag/post_2.7.46_808
    and update of ME search options in QTGMC - see ver 3.390 at https://github.com/realfinder/AVS-Stuff/blob/Community/avs%202.6%20and%20up/QTGMC.avsi
    Now new ME options to test are
    QTGMC(..., Refinemotion=true, RefineMotionAll=true, search=8,searchparam=4, trymany=true, RefineMotionSearch=8, RefineMotionRadius=8, PNew=10)
    Though as I see at https://github.com/pinterf/mvtools/blob/a488b095c4bdc8d81abfd952ab534c015a9d45b7/Sourc...lanes.cpp#L191 all coarse levels in MAnalyse always search with exhaustive (search=3) and user setting only active for refining at the finest level. So in the version post-2.7.46_808 this search was also replaced with 'more isotropic' exhaustive(2) and it will change most of the MAnalyse results in all functions with this filter calls.
    Also from v3.392s https://github.com/DTL2020/AVS-Stuff/blob/Community/avs%202.6%20and%20up/QTGMC.avsi - added dual-stage refining from Blocksize to BlockSize/4 (overlap is auto-scaled internally). Test shows at complex motion blocksize interpolation 32->16->8 works generally better in comparison with single refining 16->8. And downsize to 4x4 looks like no working good. So with version settings to check:
    BlockSize=32, SubPel=2, ChromaMotion=true, GlobalMotion=true, Refinemotion=true, Refinemotion2=true, RefineMotionAll=true, search=8,searchparam=2, trymany=true, RefineMotionSearch=8, RefineMotionRadius=4, PNew=10
    For the final blocksize of 8.
  26. Originally Posted by DTL2023 View Post
    The new options to put in the original command line of Skiller doesn't work for me but i'm in the Hybrid software, I guess I will need to wait until Selur updates the software and adds these new options to put in the command line.
  27. since DTLs version is Avisynth only, there are no plans to add this to Hybrid atm.
  28. Originally Posted by Selur View Post
    I understand. Although since your software have Avisynth too it shouldn't be that hard no? Or maybe i'm not understanding this well.
    Anyways, for now the original script of Skiller + using MC Temporal Denoise at very low/low presets and an extra sharpen with CAS of only 0.020/0.030 works very good for me and i'm very happy with the quality and the sharpness of CAS, even better when using EdiMode="RepYadif" for still parts of the video like text when I want to deinterlace other type of videos where there are a lot of text and things moving in the background.
    About the original script of Skiller, I modified it in my case to adapt it to Hybrid since some options are already in the UI with buttons to prevent conflicts when adding those same options in the command line making them "duplicated" and showing me errors when I try to process the video.
    [Attachment 92481 - Click to enlarge]
    This is how I do it in Hybrid with my modified script and the part where the UI already have some of those options in buttons, i'm very happy with the results so far so there's no problem if those new options of DTL are not in Hybrid for now, take your time to add them in the future or if you don't plan to add them in the near future there's no problem too.
