My first attempt to use this tool to remove chapters from an mp4 video and merge all the others (to remove ads). The original video was 1:50 with the commercials. I figure that without the commercials it should be 1:43 in length, but for some reason it always comes out to 1:57 after cutting and merging. So instead of getting seven minutes shorter, the video ends up 7 minutes longer? It's probably a simple oversight of some setting I'm not doing? I'm using the latest version, and I tried doing it a couple different ways: Right clicking on the advertisement segments and selecting remove, then merging the remaining segments to one output file. Also tried exporting all the segments individually, deleting the ad segments and then merging the remaining segments in a separate operation, but the length results were the same. Anyone know what I'm doing wrong? TIA!
25fps vs. 30 fps video? did you check which system - euro 25p or usa 30p was being created?
Well, I checked, and from the Windows properties I see the original videos frame rate is 29.97 fps, while the new merged video is showing as 26.63 fps? You would think that a "loseless" cutting software would preserve the original frame rate by default? I don't see any settings in the software to set the frame rate, is there some other software that can just modify the frame rate of the video?
Lossless audio codec with no filesize/length limit?
By SlyCooperReloadCoded in forum AudioReplies: 8Last Post: 28th Oct 2021, 17:43 -
How to use mkvmerge to cut/remove certain parts of the video
By MonsterMMORPG in forum EditingReplies: 5Last Post: 2nd Mar 2021, 09:59 -
Lossless Cut Problem
By FL-Artist in forum EditingReplies: 8Last Post: 25th Dec 2019, 21:45 -
Incorrect video cut timing on MKV video with lossless quality
By may5224 in forum EditingReplies: 8Last Post: 19th Nov 2019, 16:02 -
Problem with Lossless Cut
By FL-Artist in forum EditingReplies: 1Last Post: 3rd Feb 2019, 10:40
