  1. Very difficult to separate the video time line after splitting. Is there a sure shot way to do this?
    Thanks regards
    [Attachment 62513 - Click to enlarge]
    This is already split into two, but can not separate it.
  2. Member Cornucopia's Avatar
    Depends on the editor, and the edit mode (neither of which you specified). More info needed.
    But in general, you select from split point onwards and drag to later.
    Or you fork timelines.
    Or you create a new timeline and select postsplit and copy and paste.
    Probably other options.
  3. Originally Posted by Cornucopia View Post
    Its VSDC
