I have some video files that I want to merge together into one video file as the dump was originally one video file. The problem is that one of the video files has a different resolution than the other ones even though it used to be apart the exact same video. Can anyone help me merge this file with other ones?
You could try to remux the single video parts to ts and merge the ts files,
if the codecs are compatible with ts container.
Can be done with clever Ffmpeg-GUI. -
How do this in AVIsynth?
Other than a playlist (text metadata), which has pauses, container formats may have issues with different rez material.
Ones that usually work well with different rez:
MPEG2 TS
MKV
MOV
Ones that sometimes work with different rez:
MP4
WMV
Ones that don't work with different rez:
AVI
VOB (not within single vobs or vob chains)
MPEG2 PS
MPEG1 System Stream
Real
Scott -
I usually just put the clips on a timeline and export as a completed video in those NLEs. Is that a good thing?
Yes, see post#3. The NLE will do good things silently under the hood and probably save you some headaches.
How do merge video files with different resolutions together?
By Guernsey in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2021, 17:02 -
Cannot merge 2 videos after encoding one
By Budman1 in forum Video ConversionReplies: 3Last Post: 14th Nov 2020, 03:06 -
How Merge 1 Video to 100 Videos (Intro + Multiple Main Videos) help
By Squid Ward in forum EditingReplies: 0Last Post: 4th Sep 2020, 10:27 -
Need a way to view the dimensions/resolutions 1k+ videos in Windows folder
By AshleyQuick in forum Newbie / General discussionsReplies: 5Last Post: 28th Jul 2018, 10:37 -
How to merge two videos of the same tape?
By videon00b in forum EditingReplies: 4Last Post: 15th Jan 2018, 00:20
