I have a Humax 5400 PVR, on which I save TV programmes for later viewing. Sometimes I like to save video files on to my computer for convenience. Normally I transfer them using a USB memory stick, and this usually works well - plug the USB stick into the port on the front of the PVR, and then copy the file(s) on to it.
I have just encountered a problem when attempting such a transfer. The 'file manager' display came up with a message which said that the file concerned (a TV programme) was too large: I think it said bigger than 4GB... My guess is that perhaps this particular programme was recorded in HD, hence being larger than usual.
Am I right in thinking that this is a limit of the USB stick - which is formatted FAT32? And if so, how do I overcome it? I tried reformatting the USB stick as ext4, but the PVR doesn't recognise it. Would a reformat to NTFS be a solution?
Yes, you are thinking right. FAT32 supports filesizes of max 4GB. So formatting your USB stick to NTFS will indeed solve your issue.
Thanks for that quick reply. Unfortunately I don't think we have a solution yet.
Since posting my question, I tried an experiment - I reformatted the USB memory stick to NTFS, and plugged it into the Humax PVR. The stick was simply not "seen" at all. It did not appear to be recognised as a device, and did not show up in the 'file manager'.
So what other possibilities might I explore? -
An update and I have the solution to my problem. So I post it here for anyone else's benefit.
After extensive internet searching, I discovered that the Humax PVR can only recognise USB sticks which are formatted in either FAT32 (which seems to be the usual default) or ext3 - which is one of the formats Linux uses.
So - as a Linux user - I reformatted the USB stick to ext3... and the PVR sees it, and I can easily transfer large files from one to the other. Problem solved!
video playback from memory stick
By Skaperen in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2021, 07:40 -
Panasonic TV not displaying subtitles from USB stick
By millsy5 in forum SubtitleReplies: 34Last Post: 13th Feb 2021, 16:34 -
Sony memory stick duo compatability
By peebs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Nov 2018, 11:22 -
Humax Foxsat HDR USB
By Captainfearless in forum Off topicReplies: 0Last Post: 20th Jun 2018, 06:06 -
Fix: TV or player not recognizing USB memory stick
By Doogy2Shox in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th May 2017, 14:47
