Trying to deinterlace a vob dvd with progressive scan type. It does have some interlace frames. However is it possible to pass telecide hints into qtgmc instead of TDeint(clip2=src, Full=False, Type=2, mode=0, tryWeave=false)
I have selected TDeint in qtgmc but i am not sure if i am doing it right. Both MatchEdi="TDeint" and MatchEdi2="TDeint" needed, or one or another?
TDeint has clip2=src but qtgmc has nothing so i am not sure if it is accepting the hints from telecide.
Code:AssumeTFF() Telecide(guide=2, post=1, vthresh=30, back=1, bthresh=50, hints=true, show=false, debug=false) QTGMC(preset="Medium", InputType=3, SourceMatch=3, Lossless=2, MatchEnhance=0.50, MatchPreset="Medium", MatchEdi="TDeint", TR0=2, TR1=1, TR2=1, MatchPreset2="Medium", MatchEdi2="TDeint", Sharpness=0.5, SLMode=4, Rep0=4, Rep1=4, Rep2=4, RepChroma=true, NoiseProcess=0, NoiseRestore=0.0, GrainRestore=0.0, ediThreads=8)
You should always provide a sample showing the problem.
If there are stray interlaced frames you can deinterlace just them using TDeint(Full=False) or VInverse().
If the video is progressive (mostly), then why use Telecide at all?Last edited by manono; 20th Dec 2021 at 17:52.
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Duration : 41 min 55 s
Bit rate mode : Variable
Bit rate : 5 007 kb/s
Maximum bit rate : 7 500 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.483
Time code of first frame : 00:59:59:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first f : Closed
Stream size : 1.47 GiB (88%)
There are scenes that traditional deinterlace can't do, even QTGMC on its own failed. I have telecide progressive frames and those scenes looks crap until i used telecide follow by TDeint and those scenes were fixed. Basically i want to use qtgmc instead of tdeint.
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 02:01 -
Help with QTGMC
By Xyena in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2020, 12:25 -
I think this just needs QTGMC...
By pooksahib in forum Video ConversionReplies: 2Last Post: 30th May 2019, 03:12 -
Help with QTGMC?
By attackworld in forum EditingReplies: 3Last Post: 26th Nov 2018, 21:57 -
Frustrated with QTGMC
By guayabito in forum Newbie / General discussionsReplies: 19Last Post: 8th Oct 2018, 04:15
