Hello all: I work with a civil rights law firm and we were recently given a batch of VAC files, which are recorded prison phone calls. The file type seems to be proprietary by the company that facilitates the calls, GTL. They offer a player for the files, but we were hoping to convert them to WAV or MP3 so they could be played easily by multiple people.
I have tried to play VAC files on countless players, only their proprietary software plays them.
I have tried to convert on multiple conversion programs, nothing will recognize them.
I found a post here from 2016 that GTL offers a program to help with this, but I've called GTL and they said that they do not.
Is anybody familiar? Has anybody converted these in the past? Hoping for a holiday miracle here, thank you for even reading this.
Part of the reason they may be proprietary may have to do with security and privacy, which bypassing can open a BIG can of worms.
But assuming you already have written approval from all involved parties (person at prison, other caller, prison/legal authorities/administration, GTL), it might be possible to do a playback-while-capture using the proprietary app and a "what you hear is what you get" audio card driver, or similarly enabled app.
Scott -
Thanks for the reply Scott. There are a massive amount of calls, we were hoping to use the audio capture route as a last resort.
And you're most likely right re: security & privacy. -
Off the top of my head, I know of NO apps that support that file format.
Although, it may be a nonproprietary format disguised as one to limit use. Check header similarities with known common formats using a hexeditor.
However, you might still be confounded in doing an extension rename - even if it is common after all - if the data stream is encrypted. Very possible.
help needed how do you extract a SRR files on windows pc
By elm in forum Video Streaming DownloadingReplies: 2Last Post: 4th May 2021, 08:27 -
Help needed trying to figure out old DVD slideshow files for conversion
By jfspartners in forum Video ConversionReplies: 13Last Post: 18th Jan 2021, 13:34 -
help needed can i rip a disc or extract the video files like in the 1st pic
By elm in forum EditingReplies: 1Last Post: 16th Mar 2020, 03:11 -
Are timecode files needed when extracting audio to use in a different video
By beany in forum Newbie / General discussionsReplies: 8Last Post: 8th Dec 2019, 12:04 -
Security Camera .264 Video Conversion Help Needed - Bounty!
By steveholtam in forum Video ConversionReplies: 4Last Post: 25th Aug 2017, 11:32
