Hello! Is there an alternative for N_m3u8DL-CLI that also uses binary merge to join .ts files? It works perfectly on Windows but I am looking for a similar tool that I can run on Google Colab. I have tried ffmpeg, yt-dlp, hlsdl, vsdownload, etc. but they can't process files with SAMPLE-AES encryption. Or the downloaded video file has "no metadata". It says "No movie found in the file" when I check on mp4info.
Thank you!
Results 1 to 10 of 10
Thank you for the suggestion but it seems to be a Windows executable too. I'm looking for one that can be run on Colab.
Tried to install it via pip but it's missing a file called setup.py.
Code:Collecting https://github.com/xhlove/XstreamDL-CLI/archive/refs/tags/1.3.8.zip Downloading https://github.com/xhlove/XstreamDL-CLI/archive/refs/tags/1.3.8.zip \ 1.8 MB 5.0 MB/s ERROR: File "setup.py" not found for legacy project https://github.com/xhlove/XstreamDL-CLI/archive/refs/tags/1.3.8.zip.
@oknchm
from developer:
Code:no setup.py just run python -m XstreamDL_CLI.cli
MediaInfo CLI command
By UserName351 in forum Newbie / General discussionsReplies: 11Last Post: 22nd Nov 2021, 15:28 -
Unable to use N_m3u8DL because of | in header
By ng.newbie in forum Video Streaming DownloadingReplies: 7Last Post: 28th Sep 2021, 13:21 -
Xvid 1.3.5 (CLI)
By LigH.de in forum Video ConversionReplies: 5Last Post: 18th May 2021, 15:17 -
Xvid 1.3.5 CLI issues
By Selur in forum Video ConversionReplies: 30Last Post: 12th Oct 2020, 01:25 -
mediainfo cli
By zerobyte01 in forum Newbie / General discussionsReplies: 4Last Post: 20th Jul 2018, 17:41
