Hi guys so a bit of a stilly question im adding text to the timeline in vegas and it usually comes in the default of 10 seconds or so. When i edit it in the media generator and put it to 5 it does change the clip to 5 seconds but on the timeline it doesnt change and it then repeats the first 5 seconds. Now i know you can just easily drag it to the little grey triange icon that appears on the timeline where it shows the media will repeat but i was wondering if there was an option that lets the timeline change as well when you edit the duration in the media generator?
				Results 1 to 1 of 1
  MKVToolnix - How to clip a video to exact time stamp (in seconds) ?By sillymovie in forum EditingReplies: 1Last Post: 14th Aug 2020, 17:58
  Set subtitles to start at a specific time code using Subtitle EditBy seorimpaek in forum SubtitleReplies: 1Last Post: 28th Jul 2020, 23:03
  Playing Audio at specific time with AVISynthBy smike in forum EditingReplies: 4Last Post: 5th Jun 2020, 21:39
  Question about Vegas - clip size / project size / system loadBy P195 in forum Newbie / General discussionsReplies: 2Last Post: 20th Oct 2019, 23:17
  How to set the thumbnail of a video clip?By mismgmt in forum EditingReplies: 1Last Post: 25th Feb 2018, 06:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
