The Sharp QC-54 is a vintage camcorder that actually uses a vacuum tube image sensor. But for some reason either the ebay seller or someone who had it before them, cut the cable. Ths problem is these had their cable hardwired in, so you can't just replace the cord. Also it's a special 10 wire cable, that originally had a VERY uncommon connector, a 10 pin Hirose connector designed to connect to vintage camcorder power supplies. Ths single cable contains wires for power in, and video out, and audio out, as well as a pause signal to stop it from recording remotely if connected to a VCR with this special connector instead of a power supply with that connector. That means replacing the cable will require finding a special connector and correct cable. Good luck with that.
Results 1 to 1 of 1
Need some help on getting a 10-pin hirose camcorder cable
By Videogamer555 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Jan 2021, 04:36 -
HDMI to Coaxial ( cable) cable adapter
By zmann96 in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2019, 16:21 -
anyone genius here able to solve this problem ?
By midi23 in forum Video Streaming DownloadingReplies: 6Last Post: 8th Dec 2018, 12:24 -
Trying to find AV cable for vintage camcorder
By Trix in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2018, 18:50 -
Sony Z1 mini-DV tape to Final Cut Pro on mac: which camcorder?
By FayeD1977 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 15th Mar 2017, 11:39
