Hello dear community,
I am not sure, if this would be possible.
I use ffmpeg and would like to convert a Dolby True HD track (which I canīt play on my TV) into a DTS-track with the following parameters.
Codec: DTS
Samplerate: 48000
Channels: 5.1
Rate: 1508
Bits/sample: 24
Volume: 6db
I know, clever ffmpeg could do this job for me.
But there seems no setting, where I could change the parameter into 24-bits, if this would be possible.
In this case, when someone could give me the specific command line, which I could put into ffmpeg, I would really gratefull.![]()
Yes, this is indeed, what I need.^^
However also in this case, I would need a command line, because I couldnīt figure it out, how I have to write it into this programm.
Does anyone know a very easy way to convert Dolby True HD to FLAC?
By Talhah in forum AudioReplies: 4Last Post: 15th Jul 2021, 12:10 -
Dolby True HD and DTS MA issues with Editing mkvs help!
By Murray in forum EditingReplies: 2Last Post: 13th Oct 2020, 05:29 -
Muxing Audio - DTS/Dolby
By Chiccha in forum AudioReplies: 9Last Post: 17th Jul 2020, 16:50 -
AC3 core, or downconverting Dolby True HD?
By bagmand in forum AudioReplies: 6Last Post: 7th Jun 2020, 02:24 -
How to convert DTS-HD / HDMA With bitrate 1509kbps to DTS 755kbps ?
By PrinceSwaraj in forum AudioReplies: 16Last Post: 17th Apr 2018, 16:21
