Results 1 to 22 of 22
    Oct 2006
    [Attachment 62432 - Click to enlarge]
    Can anybody identify this cable for me?
    It looks to be a camcorder video output cable - but I'm looking for a more specific identification.
    The connector is more or less rectangular with 8 lines/lanes and an off-center notch.
    The other end is the usual composite AV and s-video.
  2. it has probably CVBS (yellow), Audio L+R (white+red) and RF coax (black) - device using this cable must be able to produce RF signal and CVBS with Audio - some game console? rather old one...
    yep, agree, probably S-Video, overlooked this dent - wire it look so thick, almost like RG-59...
    Last edited by pandy; 19th Dec 2021 at 07:48. Reason: S-Video not RF PAL connector
  3. The black connector looks like s-video to me. Note the little dent in the side.
    Jun 2005
    Vermont
    I agree S-video.
    Feb 2006
    the other end in the lower left picture is called a mini DisplayPort
  6. Mini Display port is digital only, the picture shows only analog connectors at the other end, so no Mini Display Connector.
    This is probably s proprietary camera connector.
  7. Mini Display port has 20 pins. The pictured connector only has 8.
  8. Member Skiller's Avatar
    Oct 2013
    Germany
    It's a proprietary connector of a camera or older cell phone to connect it to a TV.
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    camera or game console cable.
    Oct 2006
    Thanks for the replies.
    I did specify in the original post that it was s-video so I'm unsure why that became a topic of discussion. Sorry if the picture didn't show that clearly enough.
    I already believed it to be a proprietary cable from a camcorder but I was hoping somebody here might recognise it and be able to give a more specific identification. Such as which camcorder or series of camcorders it was from.
  11. Member Skiller's Avatar
    Oct 2013
    Germany
    All camcorders I have ever seen use AV connectors that look like headphone jacks.
    This kind of USB-lookalike I have only ever seen in cameras.
    Oct 2006
    I'm beginning to agree that it is more likely to be from a camera - but I have definitely seen plenty of camcorders with proprietary video output cables.
  13. Member DB83's Avatar
    Jul 2007
    Must ask. Why ?
    Now if you had the camera/camcorder and needed a bespoke AV cable I could understand an enquiry. But here you have a cable and TBH there is fat chance of a firm ID. It's like having a lace and asking of the shoe it came from
    Oct 2006
    Must ask. Why ?
    Not really - a lace could be used in any shoe; it's not restricted to only being used with the shoe it came from.
    To answer your question, it's mostly just curiosity. I hate throwing things like this away but I wouldn't know how offer it a second life with someone who'd use it without knowing what it was intended for.
    However, I now believe it is for the "accessory terminal" on a number of Nikon DSLR cameras. I can't verify it but the connector certainly looks the same.
  15. Member DB83's Avatar
    Jul 2007
    Fairy nuff.
    My dad's Coolpix has a usb-c type connector. The only av cables I could find tho were just composite. Nothing with s-video.
    Oct 2006
    Oct 2006
    Oh dear. Now I'm even more confused.
  18. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    Oct 2006
    That looks like a different connector to me.
  20. Other Panasonic AV/S cable images are clearer with a different connector. From a defunct ebay listing:
    That could be a different cable though.
    Oct 2006
    Every camera manufacturer provides cables similar to this one. It's the proprietary connector that distinguishes them - and I haven't seen anything to suggest that Panasonic uses the connector that my cable has.
