Hi all,
I try download subtitle from site RTSUn
Note: A Swiss VPN is necessary (I can provide a log if necessary)
I tried the following way (which works most of the time)
I also see this stream for MTB subtitles (there are multiple segment, segment-1-f8.vtt, segment-2-f8.vtt, segment-3-f8.vtt,)yt-dlp --write-subs --skip-download "https://rts-vod-amd.akamaized.net/ch/hls/12708469/62db96d7-1e31-3c58-9f77-b55b4d597b67/master.m3u8"
Thanks for your help
Results 1 to 9 of 9
I know this is the correct channel for this post, but you may consider relocating to Video Streaming Downloading. Just a thought. Please close this post if considering relocation.
Hi jack_666,
yes I will do that because there was no answer
Otherwise, how are you ? Still in your projects, have you made progress?
To the pleasure... -
I tried different command with FFmpeg but still errors
ffmpeg -i "https://rts-vod-amd.akamaized.net/ch/hls/12723307/0da3c5d8-be70-3756-9f87-26d34a594e46/index-f4-v1-a1.m3u8" sub.vttYou might want to try this one : https://www.rts.ch/play/tv/telefilm/video/la-reine-de-nol?urn=urn:rts:video:12723307ffmpeg -i "https://rts-vod-amd.akamaized.net/ch/hls/12723307/0da3c5d8-be70-3756-9f87-26d34a594e46/index-f4-v1-a1.m3u8" -scodec srt subs.srt
Re: TheGreatCourses and Downloading Subtitles?
By Disco Makberto in forum SubtitleReplies: 4Last Post: 26th Feb 2021, 02:31 -
By Disco Makberto in forum SubtitleReplies: 2Last Post: 25th Feb 2021, 18:58 -
Downloading subtitles from rtve.es
By AllisOne in forum SubtitleReplies: 6Last Post: 22nd Oct 2020, 12:19 -
Downloading subtitles from online streams
By monks19 in forum Video Streaming DownloadingReplies: 6Last Post: 4th Sep 2020, 12:40
