Hi guys, I've been searching around for a way to get the recorded signal from a VCR while recording. Is it possible in any way?
I want to monitor the recorded signal, from the tape, while recording. I am artist/hacker/tinkerer and it could be neat to be able to use the VCR as a "live" video effect.
I've seen people make tape loops with VCRs so if it's in no way possible to do this, on any machine, maybe one could record the signal on one deck, send it into another deck and play it back, with some delay of course (which I don't mind)
Link to VHS tape-loop:
https://www.youtube.com/watch?v=ASex_ZPYwPk
Best,
Dogenigt
Results 1 to 13 of 13
Iirc, On standard consumer decks, there are 2, or 4, or 5, or 6 heads. They are in pairs except for the 5th head which was used for "trick play", or non- standard motion options (slomo, fastmo).
1st pair = standard play (SP) Record/Play, sometimes also extended/superlong play (EP/SLP) record/play
2nd pair = long play (LP) record/play, also sometimes ep/slp r/p
3rd pair = hifi audio r/p
The need for different heads for different speeds has to do with signal optimization because the different speeds change their angle of travel on the tape.
So one cannot really use one as a substitute like you intend.
With that in mind, I don't see you being able to do what you want with consumer & commercial decks without MAJOR reworking of the innards. Better polish up your EE and ME degrees.
Scott -
Why would you want to get the output from a vcr head while recording?If it could be done there would be instants of it in google.The signal goes directly to a video tape so it would be much easier to get the signal going to the vcr and view it or send it,
Plus, the way the rotating heads work with the tape path, there is really only 1 head travelling past the tape at a given instant. It's not like you could fast-switch alternating heads or something - there just isn't enough contact with the tape to do that.
The idea of passing the tape from one machine to another is also a bit far-fetched. You woud have to have a quite complex arrangement of modded cassettes, tension relief, guide rollers, etc. A true Rube Goldberg device. For what? A delay device? Remember, the true tape speed is quite low, so going from machine to machine would add a heck of a lot of delay. That could easily be done just by delaying the incoming signal. Or by playing back afterward.
I wouldn't touch this project with a ten foot pole. Not worth the effort.
Scott -
Only pro decks had this feature (Betacam decks) and it is not for the purpose you are seeking, It is for minimizing generational loss during tape editing, So a pair of heads would read the signal recorded on tape and mix it with the incoming signal and send the mixed signal to a second pair of heads that follows the first pair with a flying erase head in between to erase the signal that has been just read by the first pair and lay down the new mixed track on tape. This would normally require two tapes and two decks which mean a loss of quality but Sony came up with this idea to minimize the quality loss and also save money on buying more decks. I will post a link to a YouTube video about this.
I suppose you can use one of those decks the way you want by just not mixing any signal to the original signal but the delay is not going to be noticeable, a field or two is the most.
Here you go, I found it:
https://youtu.be/_puGWzBmljMLast edited by dellsam34; 18th Dec 2021 at 07:54.
Thanks a lot! very educational video! Will look into beta-machines with this pre-read function. Did I understand it correctly that you can output the recorded signal with this dynamic read function after it has passed the rec head? Or only pre-read from the read head BEFORE the rec head? Any analog tape VCR machines with this functionality? I'll go scouting, thanks again.
I don't exactly know the nuts and bolts of the pre-read feature but the user manual should explain it in details, I believe only digital decks have this feature however some are backward compatible with analog Betacam recording so not sure if the feature can record analog video or just digital Beta.
Note again that those are pro, broadcast-level, component BetaCam (or DigiBeta) decks, not consumer y/c color-under BetaMax decks.
They cost $8-10k at minimum and well over $100(200?)k at maximum. From memory, am pretty sure the BVW (broadcast) line of Sony optionally had that capability, but the more economical PVW (production/commercial) line had neither of those as options. Certainly not consumer decks.
What dellsam34 mentioned has both confidence heads (after record, for review), and pre-read heads (for optional preview, FX edits). Preread heads never got real popular, because anybody who could afford already a deck like this, along with the videomixer/switcher, monitors & peripherals, likely could also afford to just get a standard BVW and a few extra PVWs as source decks, and be able to have an easier time of setting up and doing the edits the normal way.
Scott -
The cost then, Now they can be had for almost nothing depends on where you live obviously. eBay prices are inflated and do not represent the true value of the item, Most people who buy old gear from eBay buy it for nostalgia purposes hence the inflated prices for stuff that has no real purpose today. I mean take a look at this one, who would buy it for that much and for what purpose?
Gear like that has lots of hidden costs WRT support. That particular deck looks beat up. Getting back into optimal working order will very likely cost (in addition) 2x-3x times what it appears to be going for, mainly because of the rarity of replacement parts, and the skill ($$) necessary to properly fix & set up. And as I said before, these decks don't work in isolation - mixer/switchers, genlock, TBCs, etc, with "timed" cabling between - are all necessary to get out of this deck what is expected/intended.
Scott -
When I was presented with few Betacam SP tapes to convert to digital files I had to find the smallest and cheapest deck I could find that can playback at least one or two SD formats and keep getting more decks for other formats as the need arises, It turned out Sony did make small (size of consumer VCR), cheap and multi-tape compatible decks for all analog and SD digital Betacam format for both small and large cassettes (Betacam, BetacamSP, DigiBeta, BetacamSX, MpegIMX), Sony J30-SDI and Sony J3-SDI, not only that, they equiped the decks with state of the art ADC for analog tapes with TBC, DNR and Dolby C decoder for tapes with such audio encoding. The deck outputs digita SDI and can be transfered to PC with an after market SDI/USB3 adapter.
So what those microwave size decks accomplish today? I don't know, Besides nostalgia maybe some people are still recording on them. -
See, I wouldn't mind the hassle, if I knew it was theoretically possible. Now, I don't know enough about VCRs to know if the tape speed on playback and record is the same, or would the tape be spinning in different speeds in the two machines. Or if I would somehow have to sync the motors in the two VCRs to start at the same time to achieve this. I have been looking for a solution to "how to get record and play back a VHS tape loop live" for some art purposes, just haven't found anyone doing something like that, so I'm not sure if it is plausible.
But seeing the tape loops, this does seem slightly more doable.
From the little I know, it looks like you could feed a tape loop into machine 1 and a different loop into machine 2, then splice those loops together to get the completed loop from machine to machine. But thats where the rubber meets the road. How to get the machines to start at the same time, how do I make sure the tape spins in the same direction, at the same speed. Thats where my know how ends. -
Maybe not directly from a single head as multiple heads pass over the tape sequentially, but for the head switcher circuit output (responsible for switching between playback heads and stitching the signals from the separate heads back together into a single video signal) for sure would be possible. The people replying to you and saying "you can't read from a single head" are not taking into account that there's this head switching circuit, and it's actually from this circuit's output that you would be recording the signal. I read elsewhere on a tape archiving thread (I don't remember if it was in this forum or a different forum), it being mentioned that they were able to obtain highest quality video signal output from directly recording the signal out of the head switcher circuit, rather than from the composite video output. Of course this requires additional high speed analog capture hardware (you won't be using your video cap dongle for this, as the signal levels at the video head are not at all NTSC baseband signal levels, and so there's no possibility to sync on frames and capture whole frames). What you would be doing with this setup, would be digitizing the raw waveform, similar to how a soundcard captures the raw waveform of the line-in or mic-in ports, and then using additional software to analyze the signal and extract the frames. Of course you need a LOT higher bandwidth for capturing composite video than for capturing audio, so your analog capture device will need to have a sample rate of at least 9MHz (to capture the full 4.5MHz video bandwidth of NTSC video signal), or a bit less on a VCR (since most VCRs don't capture or playback the full bandwidth). And this equipment that can just digitize a raw signal at such a high sample rate goes out of the bounds of consumer equipment, and is called a "high speed digitizer". This is scientific equipment you could expect to find in specialized signal analysis situations in electronics labs. And if you think this sounds like expensive equipment, IT IS! Expect to pay thousands for a high speed digitizer (or hundreds if you are lucky and can find one made by a cheap company, or a used one on eBay). The thread I mentioned before describing how to do this mentioned other equipment that was cheaper for the digitizing, but I forget what they said they used.
Replacement video head for JVC HR-S4800U VCR
By mnrwest in forum Capturing and VCRReplies: 19Last Post: 4th Oct 2021, 19:23 -
Is LP VHS being read by SP head or EP head?
By digicube in forum Capturing and VCRReplies: 2Last Post: 16th Feb 2021, 16:44 -
Hello,From Rebecca in Etobicoke Ont, I just purchased a Daytek 6 head VCR
By Pintos in forum Capturing and VCRReplies: 2Last Post: 8th Jun 2020, 11:34 -
VCR Head-Switching Noise On Capture
By TazDave in forum Capturing and VCRReplies: 1Last Post: 1st Mar 2018, 22:17 -
Sharp 8 Head VCR
By dave_van_damme in forum MediaReplies: 9Last Post: 29th Mar 2017, 04:26
